Deke Posted January 30, 2011 Report Share Posted January 30, 2011 Hi, I have used the V280 on 5 machines and I would like to update them to a V560. On the V280 I was able to have control of which Var I wanted to edit and which var I was currently a,t like a cursor by inversing the Var. This made it so I did not have to use the touch screen, I am able to do everything from the keypad. Will I have this same control on the V560? or will I be forced to used the touch screen? Thanks, Deke Quote Link to comment Share on other sites More sharing options...
Stein Yair Posted January 31, 2011 Report Share Posted January 31, 2011 Yes. The functionality is the same as in the V280. Use right and left arrows to move between the variables and Enter to open the virtual keypad. Quote Link to comment Share on other sites More sharing options...
External Moderators tmoulder Posted June 25, 2012 External Moderators Report Share Posted June 25, 2012 For my own clarification - the 560 is basically a 570 in a 280 housing, correct? (I know, some differences, but that's the gist of it?) Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 26, 2012 MVP 2021 Report Share Posted June 26, 2012 Tim - Yes. The V560 can keep the user's grubby hands off the touchscreen. Joe T. Quote Link to comment Share on other sites More sharing options...
