drr Posted December 27, 2017 Report Share Posted December 27, 2017 I have a Samba sm43-j-r22. The keyboard which is shown when I touch a numeric/ascii control is like the attached "picture_1.jpg", but I have seen that in the "Boot Mode" of device the display shown is like the attached "picture_2.jpg". Is possible to change the keyboard type to use the same as "picture_2.jpg". Quote Link to comment Share on other sites More sharing options...
Cam Posted December 28, 2017 Report Share Posted December 28, 2017 When selecting keypad entry on a numeric variable you can select the key board type displayed here. If you click on the magnifying glass you can get a preview. I don't believe you can access the info mode keypad on a variable entry. Quote Link to comment Share on other sites More sharing options...
drr Posted December 28, 2017 Author Report Share Posted December 28, 2017 I do not mean the numeric type or with strings, I mean the look and feel... the second keyboard has a different look & feel. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 28, 2017 MVP 2021 Report Share Posted December 28, 2017 1 hour ago, drr said: the second keyboard has a different look & feel. Yep, and sadly that is not available outside of INFO Mode. Quote Link to comment Share on other sites More sharing options...
