You need to provide a LOT more information before someone can attempt to help you.
What PLC?
Which I/O module(s)?
Is the Run command given via a Digital Output from the PLC I/O or some other communication?
Has this been a problem all along or is it new?
If this has been happening all along, it sounds like a logic error by the original programmer. If so, it may be a simple fix.
Do you have the PLC program .vlp file? If so, attach it and someone should be able to give it a look over.
  • 2 years later...
