kikep Posted September 17, 2018 Report Share Posted September 17, 2018 Hi friends some body knows how many times complete the loop on plc, i do n't know if is 10 miliseconds each loop. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 17, 2018 MVP 2021 Report Share Posted September 17, 2018 SI 0 provides the scan time for the PLC. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted September 18, 2018 MVP 2021 Report Share Posted September 18, 2018 Just a little further on Flex's correct answer, unlike some brands of plc, Vision etc do not let you specify a fixed scan length. There are ways around this, but they aren't dead accurate and are a little clumsy. It is much better to just let the plc run at it's own pace. However, to get a better idea of everything available, I would have a good read of everything listed under Help/Help/index/Scan. Program Sequencing information is a "must read" because there is very important info in there. cheers, Aus Quote Link to comment Share on other sites More sharing options...
kikep Posted September 18, 2018 Author Report Share Posted September 18, 2018 thanks for your help let me work on that... Quote Link to comment Share on other sites More sharing options...
