Hi everyone,
Am new here and new to unitronics also.
I currently purchased the  vision 1210 which I wanted to use for simulation.
Am using the EX-A2X I/O Expansion module adapter snap mounted on a Din rail.
Read a single adapter can connect up to 8 I/o modules only.
is it possible to connect more than one Expansion adapters to oplc to enable me to use more I/o modules?
if yes how?
Thanks guys.
Thanks Ausman, am having a look at the EX-RC1.
Thanks Sasdiscos, I actually thought of the snap-in I/o but I do not have one currently.
I have to order it from my agent and its gonna take a while before it reaches me. but thanks for your suggestion.
Hi Flex, am working with 30x digital inpts, 20x digital outpts, 20x 4-20ma analog inpts, 3 RTD's and 10x analog outpts.
am using 2x IO-DI16
                    2x IO-TO16
                    3x IO-AI8
                    1x IO-PT400 and
                     2x IO-AO6X
which takes my I/o modules to a total of 10.
am using 2x IO-DI16
                    2x IO-TO16
                    3x IO-AI8
                    1x IO-PT400 and
                     2x IO-AO6X
Looks like poor module selection. Unless I'm missing something, if you used the following, you would need only 7:
EX-D16A3-TO16
IO-D16A3-TO16
IO-PT400
IO-AO6X
IO-AO6X
IO-AI8
IO-AI8
Flex, you mention the larger I/Os.  My personal view on this is that Unitronics don't "promote" the larger capacity I/Os enough, and not many people know about them.  For instance, when you look at the I/O listings, you see "Digital" and it is very easy to assume that that's it.  You are only presented with the smaller I/Os.  You actually have to go down past Analogue/Temp etc to reach the higher capacity modules.  This is a big failing in my view, and the page needs adjustment to bring it all together.
And whilst on I/Os, and relating to my error above about the snap-in, I try to not use snap-ins, rather discrete I/Os for both ease of replacing and likely smaller cost in the unlikely event of it needing replacement in the future.
cheers,
Aus
