kpetro07 Posted February 20, 2019 Report Share Posted February 20, 2019 Hello All, Can someone help to build a simple program for switching multiple outputs with delay ? Condition is: Input ON, Output 1 ON then delay XX seconds Output 2 ON, and .... delay XX seconds Output X ON. Input OFF, Output 1 OFF then delay XX seconds Output 2 OFF, and .... delay XX seconds Output X OFF. thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 21, 2019 MVP 2021 Report Share Posted February 21, 2019 Is the delay between Outputs always the same? What is the maximum value for X? I would use a combination of a timer incrementing a pointer and a Set Bit block to tick the bits on in an integer tag or array, and then do a Num to Bits function to transpose the number to the outputs in bit form. You could reverse the operation using the Reset Bit block to turn them off. This method is above beginner level - what is your experience with manipulating bits in integer arrays? Joe t. Quote Link to comment Share on other sites More sharing options...
kpetro07 Posted February 21, 2019 Author Report Share Posted February 21, 2019 12 hours ago, Joe Tauser said: Is the delay between Outputs always the same? What is the maximum value for X? I would use a combination of a timer incrementing a pointer and a Set Bit block to tick the bits on in an integer tag or array, and then do a Num to Bits function to transpose the number to the outputs in bit form. You could reverse the operation using the Reset Bit block to turn them off. This method is above beginner level - what is your experience with manipulating bits in integer arrays? Joe t. WeI do not have any experience with bits in integer arrays so we have done it as attached.... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 21, 2019 MVP 2021 Report Share Posted February 21, 2019 For a less sophisticated version of what Joe is talking about, forget the word "timers" completely. I think him saying "combination of a timer incrementing a pointer" is essentially referring to what I call a counter being incremented by 1 every time cycle. I often mention that in many instances counter based systems are the much forgotten/ignored method that is a much better solution than a combination of timers, due to their simplicity of making outputs do whatever you want at a certain time......but for "time" read "a section of the count". For the less sophisticated method, use compares that set your outputs on when they fall in range on the numbers coming up as the counter is running. Once everything is on, stop the counter at that point but don't reset it. To shut down, start the counter again and the outputs are shut down progressively as the compares do their stuff. Once everything is finished, you stop the counter and reset it either at the stop or the next start signal. Accuracy needed dictates what you use as your timer that increments the counter. cheers, Aus Quote Link to comment Share on other sites More sharing options...
