John_R 12 Posted March 19, 2019 Report Share Posted March 19, 2019 Hey All, Today's dilemma..... I'm doing some data collection from a mass flow meter, saving values to a data table which I grab from the PLC using DataXport. The values I'm saving to the data table are floating numbers (MF's), and when I look at the data table the values look fine. But when I open the excel file created through DataXport, the floating numbers somehow get changed to "Number Stored as Text", and the guy who is analyzing the data isn't happy with this format.... I can do a conversion in my logic from the MF to an ML or an MI, and the guy will have to be happy with an implied decimal point to either 6 places or 3 places. But I'm wondering if anyone knows the reason for the float to text phenomenon, or how to change the way the excel file saves it? JohnR Quote Link to post Share on other sites
kratmel 63 Posted March 19, 2019 Report Share Posted March 19, 2019 I do not know if this will help, but in some programs it is a warning that when exporting to the exel, you must remember the country in which you are. In that case, excel use system separaror that is a coma or dot. It is selected in excel parameter. Please uncheck "use system separator" and use dot as excel internal separator. Then try to reopen your file. 1 Quote Link to post Share on other sites
Ausman 207 Posted March 20, 2019 Report Share Posted March 20, 2019 Curious. I'd be having a play with some of the Excel Options, particularly under Formulas and Error checking rules. There are a number of possible suspects there which might be worth a try. Particularly "Numbers formatted as text.......". I'd be having a look at your raw output using something other than excel initially, on the chance excel is indeed changing things to suit what it sees as an error. The other thing to have a look at might be to try things as a csv, and see if things improve by changing the separator in Dataexport properties. IF it can't be solved with present setup, instead of changing your program, make him a small macro that converts it. Not too hard. (Edit: Along the lines of record macro, select entire data area or bigger via drag or number input, format cells as whatever number format you want, stop macro recording. So easy that perhaps not even a macro......depends on a few variables.) cheers, Aus Quote Link to post Share on other sites
John_R 12 Posted March 20, 2019 Author Report Share Posted March 20, 2019 Thanks Guys..... It was as simple as changing the site option from "create Excel file" to "create .csv file" and using the default comma separator..... In all my other DataXport sites I've used the Excel file option and it always worked as expected, but this is my first time dealing with floating numbers... Live and Learn 🤓 JohnR Quote Link to post Share on other sites
