Matss95 Posted April 26, 2019 Report Share Posted April 26, 2019 Hi, the MB 64 wont come on after I press Key 1. I have several of this options in the program and those works fine. If I use just normal Coil it still wont come ON. The Logic above works fine. I just dont understand what can be wrong. Thanks for help. Quote Link to comment Share on other sites More sharing options...
DanT Posted April 26, 2019 Report Share Posted April 26, 2019 Hi; The Main Program scans the nets from net 1(Top) to Net X(End) - Top to Bottom - , deviating only to do called subroutines. When a Contact Output is used multiple times in the program, Only the LAST Time Used Counts because that is when the Scan does the final determination of the condition of the contact Output before setting the outputs, doing housekeeping and restarting the scan again. Where else is MB 64 being used? Subroutines are only Active when CALLED, otherwise, the subroutine and all it's internal logic is ignored. Dant Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 26, 2019 MVP 2021 Report Share Posted April 26, 2019 Please Find MB64 in your program and post result to the topic. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 26, 2019 MVP 2021 Report Share Posted April 26, 2019 And to end all those good comments above this one, all those warnings in the bottom of your screenshot fully explain part of the issue. Split your nets up so that you only have one coil per net. Just because it works in one area doesn't mean it is good practice. Remember that even though the graphical presentation shown to you looks like it will work, the plc might approach it far differently, so the reference to Stl is very relevant. All your "controls" on the left of the rung can be tallied together near the beginning of your program, controlling a batch of MBs that you use instead. You enter all your controlling parameters and then will likely be surprised at how many have commonality. This method will likely actually decrease the number of ladder elements, even doing the one coil per net, as you only have the derived MB as the input. Learn about some system delays involving HMI screens. Is MB70 actually being turned on? We are assuming that MB70 and MB45 are associated to different displays. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Matss95 Posted May 22, 2019 Author Report Share Posted May 22, 2019 On 4/26/2019 at 10:53 PM, kratmel said: Please Find MB64 in your program and post result to the topic. On 4/27/2019 at 12:06 AM, Ausman said: And to end all those good comments above this one, all those warnings in the bottom of your screenshot fully explain part of the issue. Split your nets up so that you only have one coil per net. Just because it works in one area doesn't mean it is good practice. Remember that even though the graphical presentation shown to you looks like it will work, the plc might approach it far differently, so the reference to Stl is very relevant. All your "controls" on the left of the rung can be tallied together near the beginning of your program, controlling a batch of MBs that you use instead. You enter all your controlling parameters and then will likely be surprised at how many have commonality. This method will likely actually decrease the number of ladder elements, even doing the one coil per net, as you only have the derived MB as the input. Learn about some system delays involving HMI screens. Is MB70 actually being turned on? We are assuming that MB70 and MB45 are associated to different displays. cheers, Aus Thanks, yes MB70 and MB45 does come ON when I go to the different displays Quote Link to comment Share on other sites More sharing options...
