Oldskuler Posted June 27, 2019 Report Share Posted June 27, 2019 Hi, I wanted to protect some info on my HMI using Password Box, but I can't figure out how do I choose password? I tried to use Compare Strings in ladder, but I can not compare tag that I used for Password Box, because second element in Compare Strings block can not be constant value (in my case correct password, which must be constant number). Can someone give me some tips about this? Thank you in advance. Cheers! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 27, 2019 MVP 2021 Report Share Posted June 27, 2019 Did you check the Help file? Go to Contents/HMI Screen Editor/HMI Elements/Text Elements/HE: Password Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 27, 2019 Report Share Posted June 27, 2019 Try User Access Control, a more powerful tool for your need Quote Link to comment Share on other sites More sharing options...
