Jas 5 Posted June 1, 2011 Report Share Posted June 1, 2011 Attached below is a step by step guide using VisiLogic with Vista/Win7 + UAC. UAC & VisiLogic Reinstall Instructions Vista.pdf UAC & VisiLogic Reinstall Instructions Win7.pdf Quote Link to post Share on other sites
Jas 5 Posted July 19, 2011 Author Report Share Posted July 19, 2011 If you are using a Unitronics USB to Serial Adapter (MJ10-22-CS35) please be certain to use the most up to date driver. A working copy is available on our FTP site from the link below: https://unitronics.exavault.com/share/view/14v4-dykmdjy1-db9hawg8 Quote Link to post Share on other sites
sjeggefjes 0 Posted May 15, 2012 Report Share Posted May 15, 2012 Is it supposed to work with UAC after instalation? It worked after instalation but not when I was removed from the administrator list. Quote Link to post Share on other sites
AlexUT 58 Posted May 15, 2012 Report Share Posted May 15, 2012 Hi, UAC should be disabled, and current user should have an administrative rights, or application should be run "As Administrator". 1 Quote Link to post Share on other sites
sjeggefjes 0 Posted May 16, 2012 Report Share Posted May 16, 2012 Tanks for the answer. Is there any plans for making it work with uac and not administrator rights? Quote Link to post Share on other sites
Walliemg 0 Posted November 21, 2013 Report Share Posted November 21, 2013 Hello I have found if you install visilogic in a new folder under c: drive you do not need to turn off UAC, that is what I do on all my win 7 pc's. Quote Link to post Share on other sites
Ljuba 2 Posted June 12, 2017 Report Share Posted June 12, 2017 Yes you can. I'm using VisiLogic on my Win7 laptop (x64 bit). It works just fine. You can Enable/Disable your UAC if you want, but I don't think it will change anything. Best Regards, Nikola Ljubinkovic Quote Link to post Share on other sites
