Pavel M Posted March 2, 2020 Report Share Posted March 2, 2020 Hello, i'm trying to communicate old JZ10-11-T40 with my PC, but can't do it properly. What did i do: 1. Installed driver USB-to-serial 2. Installed USB driver from U90 ladder 3. Turned ON PLC 4. Got connection from PLC to PC through this chain MJ-20PRG > MJ20-CB200 > MJ10-22-CS10 > USB-to-serial adapter When i'm trying to get PLC version - i get nothing This error appears all the time, but the interesting thing is next: When i try to get version - it is trying to synchronize COM ports and then this error above appears When i press Stop - i see PLC in stop mode, but then this error appears anyway When i press Run - i see PLC goes from stop to run mode, but this error appears anyway I was trying this on windows XP, windows 7 and windows 10 and got the same results U90 ladder version is the latest - 6.6.45 [DB 109] Any suggestions about that? I think it sends some commands, but can't receive any data, so is that a problem with MJ20-CB200 cable? Also i have JZ10-11-R10, switched hardware configuration correctly and get same results as JZ10-11-T40 ==================== 02.03.20 09:03:42.32 : < 3,9600,E,7,1> 3, 9600, 7, Even, 1, 3, 1000 > Retransmitting 02.03.20 09:03:43.32 < 3,9600,E,7,1> > Switching Com Port 02.03.20 09:03:43.32 < 3,9600,E,7,1> > Synchronizing Com Ports ==================== 02.03.20 09:04:10.32 : < 3,19200,E,7,1> 3, 19200, 7, Even, 1, 3, 1000 > Retransmitting 02.03.20 09:04:11.32 < 3,19200,E,7,1> > Switching Com Port 02.03.20 09:04:11.32 < 3,19200,E,7,1> > Synchronizing Com Ports 02.03.20 09:04:12.32 < 3,9600,E,7,1> > Retrieving OPLC Default Settings This is information from log file, was also trying to change default settings Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 2, 2020 MVP 2021 Report Share Posted March 2, 2020 Please read this https://unitronicsplc.com/Download/SoftwareHelp/U90LadderKnowledgebase/Communications/Direct_Communications-_PC_to_PLC.htm You can see that jazz PRG use pin 1 and 6 for PWR. Maybe USB-to-serial adapter do not offer correct power supply to Jazz PRG. The connection may start and disappear due to insufficient power to the adapter. USB-to-serial adapter usually uses a low power converter based on the capacitors to generate output signals, so it may not be able to power the Jazz PRG programmer. Please see this and use more pin connected to PWR line https://unitronicsplc.com/Download/SoftwareHelp/U90LadderKnowledgebase/Communications/Modems/PLC_to_Modem_Connections_and_Pin-outs.htm or try to power Jazz PRG by separate power (please read Jazz PRG manual). Try to use +5V separate power supply connected to - to GND and + to PWR. P.S. You can test Jazz PRG on puter with hardware RS232 port. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 2, 2020 MVP 2021 Report Share Posted March 2, 2020 Further to Kratmel's great answer which I would pursue first, what brand is your USB to Serial adapter? There are many out there that use fake chips, and they do not work properly. This has been discussed at length on the forum if you have a hunt around. Until you first encounter the issues they create you haven't experienced the joy of banging your head against a brick wall, trying to figure out why the &*!## connection still doesn't work. ⛔! cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 2, 2020 MVP 2021 Report Share Posted March 2, 2020 It is one more testing method for your USB-to-serial adapter. Please download terminal program (like hercules ect...). Plug USB-to-serial adapter to USB port and temporary connect 2 to 3 pin together. If you send some characters from terminal you will recieve it back if this adapter is operational. Then you can test wires that go to Jazz PRG at the same way. (connect RX + TX line together by wire without Jazz PRG). Quote Link to comment Share on other sites More sharing options...
Pavel M Posted March 5, 2020 Author Report Share Posted March 5, 2020 Hello and thank you everyone for answers That is true, im using wrong usb to serial adapter, i saw someone used CH-340 so i decided to buy some random cable with the same driver, but mine was without power on pins 1 and 6. I found old pc with com port and communication works fine Ok, we learned, thank you again Pavel M Quote Link to comment Share on other sites More sharing options...
