I use a V700 with V200-18-E3XB module.
I connect some switches to the digital inputs that work fine and some leds to the digital outputs so i can test my project.
I connect them according to snap in I/O manual pdf
 but i have no  voltage on the outputs
although in the program the output bits goes high.
Any idea what the problem might be?
1.  There are multiple locations on the -E3XB module to connect power.  Verify you have power connected to V1 and 0V.
2.  Most of the outputs on this module are relays.  Are you saying you have no voltage on them or on O0 and O1?  Are the relays on the other outputs clicking?
