How to get PLC name Vision series vision V350
phu, apart from what Flex has said above, you are obviously still trying everything to get the project out of the plc.  If this hasn't been allowed  in the first place, you can't do it.
If you have been told it is on the SD card, you can simply remove the card from the plc and read it in a PC.  To ensure no card corruption, only remove it 10 seconds after power off.
cheers, Aus
