Potenza Posted September 30, 2020 Report Share Posted September 30, 2020 Hi, I am using USL-070-B05 display panel with USC-050-T24 PLC my problem is the general.touched bit is not working. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 30, 2020 MVP 2021 Report Share Posted September 30, 2020 HMI screen calls need to be a latched bit (SET Coil) and need to be entered in the Actions section of UniLogic. Quote Link to comment Share on other sites More sharing options...
Potenza Posted September 30, 2020 Author Report Share Posted September 30, 2020 Thanks for response, My screens are working fine and are entered in Actions group. The problem is general. touch bit does not change state when I touch the screen. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 30, 2020 MVP 2021 Report Share Posted September 30, 2020 Are you saying that your finger was touching the screen when the screenshot above was taken? Do any other buttons or touch elements work? Quote Link to comment Share on other sites More sharing options...
Potenza Posted October 1, 2020 Author Report Share Posted October 1, 2020 Hi , That is correct I was touching the screen when image was taken. All buttons that I used in project are working. Quote Link to comment Share on other sites More sharing options...
Cam Posted October 1, 2020 Report Share Posted October 1, 2020 See the linked post and see if that solves the issue. You would need to be running 1.30.58 in order to do it though. Quote Link to comment Share on other sites More sharing options...
