What models of Unitronics has 1ms timer resolution?
Oleh, if you use a simple trick in the Enhanced Vision range, you can get down to a minimum of 1.25ms using an Interrupt Routine.  It is not a timer as such, but you can use it very easily to build your own.
Have a look at this post, and note the comment about 2.5ms for older models.
cheers, Aus
