charles.lin Posted February 12, 2021 Report Share Posted February 12, 2021 Hi, I am facing one issue when adding strings into the 7th row in the index data table, with no issue before that. The error message is "Value is not available". What does this mean? Thanks, Charles Link to comment Share on other sites More sharing options...
Swervomotor Posted February 18, 2021 Report Share Posted February 18, 2021 Not really enough to tell what the problem is but it looks to me like you are using local tags in the function vs Global tags. I wasn't aware of a limit but it makes sense there may be a limit to the number of local tags you can define per function. I would check your Data Table name is in the global tags area. Outside of that I would contact support. -Swervo Link to comment Share on other sites More sharing options...
AlexUT Posted February 18, 2021 Report Share Posted February 18, 2021 This is a Warning that value of this tag cannot be displayed on Ladder (display this tag in Ladder require some unnecessary data processing). But it is stored as supposed. You can check result in Data Table. B.R. Link to comment Share on other sites More sharing options...
