alighz Posted March 7, 2021 Report Share Posted March 7, 2021 Hello everyone, I have a Samba SM43-J-T20 and want to know if it is possible to connect it anyway to a Alphanumeric display that support Modbus with RS485. my goal is to send a timer value to this display. it would be great if you have any idea of how and could share it with me. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 7, 2021 MVP 2021 Report Share Posted March 7, 2021 7 hours ago, alighz said: Alphanumeric display that support Modbus with RS485 Please post model or foto of nameplate. I use this display with Samba via Modbus connnection. https://akytec.de/en/smi2-rs-485-display.html 1 Quote Link to comment Share on other sites More sharing options...
alighz Posted March 7, 2021 Author Report Share Posted March 7, 2021 Hi Kratmel, Thank you for you reply. I would like to chose one between these two . http://www.diniargeo.com/prd/scales/weight-indicators/repeaters/glr100-repeater.aspx https://www.gicamloadcells.com/98_Repeater_RIP 100 HE could you please explain me how it works and what exact module should i order? Thanks in advance. best regards Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 7, 2021 MVP 2021 Report Share Posted March 7, 2021 Hi, please post what information you whant to see on display. Something like 20:59:01 or other format. What refresh time needed? 4 hours ago, alighz said: http://www.diniargeo.com/prd/scales/weight-indicators/repeaters/glr100-repeater.aspx This one has big LED matrix but it is impossible to download any information about used RS485 protocol. Serial # of offered product needed. 4 hours ago, alighz said: https://www.gicamloadcells.com/98_Repeater_RIP 100 HE This one offer manual with protocol but only Italiano lenguage present. Maybe it is possible to program second one via Samba. If you have manual about protocol for first one - plese post to topic. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 7, 2021 MVP 2021 Report Share Posted March 7, 2021 As I was finishing this reply, Kratmel's popped up. I haven't read it yet, so will simply allow them both. The first display is perhaps using a proprietary method of communication as it says that it can "combine with indicator". It might be using standard 485 methods, but who knows. The links on their page to get manuals does not work. The second one, the RIP100 is perhaps a better bet. It says "ASCII + programmable custom protocols". The links on their page do work, but I sadly do not speak Italian. But it would appear that there are detailed descriptions on how to communicate to the unit under serial comms. The Samba you possess does not have the required comms port on board....I think. Over to Kratmel. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
alighz Posted March 7, 2021 Author Report Share Posted March 7, 2021 11 minutes ago, kratmel said: Something like 20:59:01 or other format. I want to show just the timer, Seconds in reverse. from 30 S to 0 and at the end a Short text message on display. and refresh time ideally is 1 second. I think i can find a manual about the first one, because I've seen this device communicate with serial Rs485 with PC and totally separate application from the founder. I will share it here. how about module. what module do i need and how can i install it on SM43-J-T20. I haven't seen useful thing in user manual. best regards Quote Link to comment Share on other sites More sharing options...
alighz Posted March 7, 2021 Author Report Share Posted March 7, 2021 15 minutes ago, Ausman said: As I was finishing this reply, Kratmel's popped up. I haven't read it yet, so will simply allow them both. The first display is perhaps using a proprietary method of communication as it says that it can "combine with indicator". It might be using standard 485 methods, but who knows. The links on their page to get manuals does not work. The second one, the RIP100 is perhaps a better bet. It says "ASCII + programmable custom protocols". The links on their page do work, but I sadly do not speak Italian. But it would appear that there are detailed descriptions on how to communicate to the unit under serial comms. The Samba you possess does not have the required comms port on board....I think. Over to Kratmel. cheers, Aus Thank you for your reply. I will go with second one. seems you both agreed on it can i add that comm port module to this samba ? I have no idea about expansion or I/O module with Unitronics plcs. best regards Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 7, 2021 MVP 2021 Report Share Posted March 7, 2021 47 minutes ago, Ausman said: Samba you possess does not have the required comms port on board....I think. Yes Aus, Samba do not have RS485 on board, but in second display manual we can see 15m cable via RS232 connection possible. For bigger distance RS485 (V100-17-RS4X) isolated card recommened to install inside Samba. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 8, 2021 MVP 2021 Report Share Posted March 8, 2021 I don't use Sambas, but I believe alighz's model doesn't natively have the 232 port, only the mini usb one. Would need an additional module like V100-17-RS4(X). cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 8, 2021 MVP 2021 Report Share Posted March 8, 2021 Sorry Aus, you are right - i have only 3.5 Samba with RS232 on table (RED). Topic starter have SM43-J-T20 (GREEN) Quote Link to comment Share on other sites More sharing options...
