Ben Bravin Posted March 20, 2021 Report Share Posted March 20, 2021 how can I create a blinking output for a flashing light Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted March 20, 2021 MVP 2022 Report Share Posted March 20, 2021 I usually just use SB 3 for convenience, but you can use a self-resetting timer to implement any flashing frequency you desire. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted March 20, 2021 MVP 2022 Report Share Posted March 20, 2021 This is how you would do it with a self-resetting timer: Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted March 23, 2021 Report Share Posted March 23, 2021 You can also use the drum sequencer if you want to create different flashing patterns. Quote Link to comment Share on other sites More sharing options...
MVP 2022 kratmel Posted March 23, 2021 MVP 2022 Report Share Posted March 23, 2021 One more tip - blinking with different Cycle Time and Duty Cycle. You can set different BLINK bits (like MB10) and use it for some type of machine working mode indication. Quote Link to comment Share on other sites More sharing options...
Ben Bravin Posted March 30, 2021 Author Report Share Posted March 30, 2021 thanks so much UniGuru I used both methods and they both worked ust as intended Ben. Quote Link to comment Share on other sites More sharing options...
