Jazz JZ10-11-R10
HI All
I am using jazz jz10-11-R10 and I tried connecting with PC but it does not connect, I have same model and it does connect.
same PC, same cables, same settings everything is same but one gets connected straight away but not the other.
I tried (i) + 7 to bootstrap but it stuck on "bootstrap" on screen.
I can see program on screen, edit it, run or stop but can not connect to PC to modify it or take a back up of the program.
Anyone can help to HARD RESET to factory settings so at least I can use it?
Thanks in Advance
If you use Jazz PRG adapter - please check all pins inside PLC connector. Sometimes one of them bended.
Best way compare pins in working and not working Jazz.  Pleaese note - power pins is longer than IO pins inside PLC.
Sometimes someone insert something inside PRG slot.... but not PRG adapter....
