LightSpeed Posted December 21, 2021 Report Share Posted December 21, 2021 Theres a bug with VisiLogic I encounter when switching from using a monitor with my laptop (at work) to just laptop (in the field). When I go to add or edit any operands the popup box doesn't appear. Like the software is still trying to send it to the monitor that is not connected. the only way I've been able to get it to work is if I remember to drag the box to my laptop screen before disconnecting monitor. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 21, 2021 MVP 2021 Report Share Posted December 21, 2021 Hold Ctrl+Shift while you double-click the Visilogic icon. This will reset the window settings to factory default. Hat tip @Joe Tauser 2 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted December 21, 2021 MVP 2021 Report Share Posted December 21, 2021 Further to Flex's answer, you might want to read all the background on this. It is actually linked under "Topics almost worth pinning" as Point 3. There are further tips there. I have found it isn't just a Visilogic thing. cheers, Aus https://forum.unitronics.com/topic/5827-multi-monitor-issue/ 1 Quote Link to comment Share on other sites More sharing options...
LightSpeed Posted December 21, 2021 Author Report Share Posted December 21, 2021 Thanks!! @Flex727 and @Ausman both very helpful! Quote Link to comment Share on other sites More sharing options...
