JOTA Posted May 5, 2022 Report Share Posted May 5, 2022 Hello: I am using UNISTREAM USP-156-B10. My UNILOGC version is 1.32.98. I have created a program and in some parte it creates a LOG file. The Data Table stores Date, Time, a Message and some info (Line Voltage of the system) and Motor Running Hours. THere are several lines of this message created. Below some of them: I tested this part of the program in my office in another UNISTREAM and it creates the table and stores it into a file located at an SD memory. I created almost the same sample in my app, but it seems there is somethig going on there and the file is not being created at the SD card. Here´s the instruction: I have used the STORE DTI to FILE Ladder instruction, and when creating the file, the STATUS Register returns to me -14 (it means append UDTF file Error) My program file size is larger than the approved on this forum to share, so if someone wants, I may be able to send it in a ZIP file Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted May 5, 2022 MVP 2021 Report Share Posted May 5, 2022 Moved.... Some info from forum topics... Quote Link to comment Share on other sites More sharing options...
JOTA Posted May 5, 2022 Author Report Share Posted May 5, 2022 Hello: Problem has been solved. It seems there is a mistake in UNILOGIC. I say a mistake because it is not a Bug, since it has been reported about 3 years ago and it haven´t been solved yet. In the STORE DTI to FILE function, you don´t have to choose CSV (letter F option2). When you select this option happens my case. You should select option 1 (to create UDTF, CSV, ZIP file all of them together) and it will work. Thanks Quote Link to comment Share on other sites More sharing options...
JOTA Posted May 5, 2022 Author Report Share Posted May 5, 2022 Thanks Again KRATMEL Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted May 10, 2022 Report Share Posted May 10, 2022 @JOTA, I am sorry that you ran into this issue. You are correct--it is not a bug, it is just the way it works...however, that was certainly not intuitive, and I am glad you found the correct solution. I have clarified the Help which will be released with the next version. The topic now includes a better explanation and an example - this will help future users 🙂 Quote Link to comment Share on other sites More sharing options...
