Diego Vasquez Posted May 27 Report Share Posted May 27 (edited) Hello, My name is Diego Vásquez and I hope you're healthy and safe. I'm working on a project with Unilogic 1.32.98 with a PLC USP-070-B10 with CPU USC-P-B10. I need to change decimal separator from dot to comma into the PLC because I'm exporting data into a .csv file and the decimal separator is generating problems when I open it into excel because It takes decimals as thousands. Changing system separator from comma to dot solves the problem but it is not viable because my client is not willing to do it and that's why I need to change it into the PLC. Thanks in advance. Diego Vásquez C. Edited May 27 by Diego Vasquez Redaction Quote Link to comment Share on other sites More sharing options...
Rivka Posted June 2 Report Share Posted June 2 Hello, Can you please specify from which functionality within UniLogic you are exporting data into csv file? Quote Link to comment Share on other sites More sharing options...
