Now I want to convert String to integer?
I want to save the month with only one character
1-9 is not a problem
But 10,11,12 needs to saved as
10-O                      (December)
11-N                      (November)
12-D                       (December)
I am using mm//dd for RTC
I used function:( string to left )to find the two numbers
How can I do that?
4 hours ago, Joe Tauser said:
You're not telling us what the error is.  Do a screenshot of it.
You're putting multiple logical statements in the same network again, as you did in another post.   This should be three networks.
You should store your factor (MI 889) before you call your function blocks.
Thank you so much Joe.L, like you said removing from the same ladder solved the problem.
I have one problem now
I have number and String,
I want to concatenate them. I tried to using Num to Ascii function, but this did not do it.
Eg
String1=”abc”
Mi 1= 100
Sting Final=”abc100”
How could I do this?
This a more complicated problem.  Since Unitronics Vision doesn't have string data types, you need to track where your characters are in the MI table.  There is no "concatenate" function so the problem needs to be broken down to the byte level.
Before you solve the problem you'll need to define your initial possible conditions.  How big with the number be?  How long can the string get?
You'll need a block of MIs to be a buffer for your manual string manipulation.
Step one is to determine the length of the string.
Step two is to move the string to the beginning of the buffer.
Step three is to convert the number to a string and also determine its length.
Step four is to move this "number string" to the tail end of the first string using the Vector Copy with Offset function.
Clear as mud, I know.  Have a go at it.
  • Like 1
What does
"Step two is to move the string to the beginning of the buffer" mean??
If the purpose is to display that on screen, I  find easier to use string library to concatenate and make more complex string text based on other information:
In this case  I have a composite duration  . I track the Hrs. as an Integer, then convert to ASCII, then link that value on String variable,
Then I just select in the screen the String from library to display as an ascii :
  • Thanks 2
