PierreLouis77 Posted October 25, 2022 Report Share Posted October 25, 2022 Hi, I need to know if it's possible to change the hours of the PLC without reload it. My customer is not on the same country that me. So if it's possible... TY Quote Link to comment Share on other sites More sharing options...
DanT Posted October 25, 2022 Report Share Posted October 25, 2022 Hi; In Vision PLC ( V350 to V1210 ) use Info Mode You can change the date and time from there There are 2 methods : at Info Mode Menu, Date and Time, or Operands Si 31 ( Hours/Minutes ) DanT Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted October 26, 2022 Report Share Posted October 26, 2022 you can also log in with visilogic and under connection / communication & OS/ In the Gear tab, set RTC that will sync the PLC time with the computer time. I f your customer is in another country you could use team viewer or something like that to access to a remote computer that will be connected to the PLC... assuming that you or your customer have one for that. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 26, 2022 MVP 2021 Report Share Posted October 26, 2022 OR....make one screen that is just for setting up the clock. It's easy to do. For example, setting the hours and minutes, a keyboard numeric entry with numbers restricted to 0 to 2359, and then the linked MI being used in a direct store to SI31. I've had this for years, and the thing that stands out for me doing this method is that if there is an incorrect entry in the field, like a time of 2186, the plc won't accept it. But if the time entry is correct, it does. Note the Plus/Minus was the convenient key to use in the example, nothing to do with actually altering the numbers in this case. Also, if the time zones are a long way apart, repeat runs of manual entry to stop the day rolling over incorrectly will let the days look after themselves. Or do the same storage method for the other SIs involved. You can use the same MI for different things, just changing what button you use, which changes what SI is written to. Again, if the entry is incorrect, the plc won't accept it. cheers, Aus Quote Link to comment Share on other sites More sharing options...
sgull Posted October 27, 2022 Report Share Posted October 27, 2022 Can you not just put the time variable on the screen and tick the keyboard entry box. when the time is touched the keyboard will popup to allow entry. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 27, 2022 MVP 2021 Report Share Posted October 27, 2022 sgull, maybe you can do that on bigger Visions, but I only use 130s so that's the way I've done it for a while. cheers, Aus Quote Link to comment Share on other sites More sharing options...
