Itzik Posted March 16 Report Share Posted March 16 Hello I need a solution for opc server that can connect V570. I tried the UniOPC but it's an old version and no OPC client could connect to it. I tried Matrikon OPC Explorer and Dream Report OPC Client - both couldn't connect. Is there a working OPC server I can use ? Thank you Itzik Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted March 16 MVP 2021 Report Share Posted March 16 Please send this quastion to support@unitronics.com Quote Link to comment Share on other sites More sharing options...
Itzik Posted March 16 Author Report Share Posted March 16 I did... Thank you. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted March 16 Report Share Posted March 16 I tested OPC Expert with Unitronics and it worked (the evaluation license at least) OPC Expert also allows you to "bridge" Unitronics OPC Server to other protocols like OPC UA. Wich could be what you need if you already have any other OPC client of your preference running. I tested that like 2 years ago. but at the end I ended using Modbus TCP/IP and to directly communicate to the PLCs, so no OPC server needed with this architecture. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 16 MVP 2021 Report Share Posted March 16 When I had this requirement, I purchased a UniStream USC-B5-B1 and used it as a gateway between the Vision PLC and the OPC client. The Unistream talked MODBUS TCP to the Vision PLC, collected all the data, then made it available to the OPC client. It was inexpensive and worked perfectly. Quote Link to comment Share on other sites More sharing options...
Itzik Posted March 16 Author Report Share Posted March 16 26 minutes ago, Flex727 said: When I had this requirement, I purchased a UniStream USC-B5-B1 and used it as a gateway between the Vision PLC and the OPC client. The Unistream talked MODBUS TCP to the Vision PLC, collected all the data, then made it available to the OPC client. It was inexpensive and worked perfectly. I also thought about it.... Quote Link to comment Share on other sites More sharing options...
