Modbus
Hi,
Has anyone attempted to convert modbus RTU to TCP using C# or any other PC based method?
We are about to purchase 40 energy meters that use modbus RTU for each of the machines on the shop floor, we are told by the saleman that we have to purchase modbus RTU to TCP converters to get the data on the network. At $200 each multiplied by 40, i wondering if I can get around having to buy them. Each machine has a normal PC connected to it, so I'm thinking I can send the RTU to the PC via a serial port then covert to TCP to get the data on the network.
We use USC- B5-T42 for our projects but in this instance my question is just regarding modbus as I cant do anything with the macines that we have bought in. The energy meters are independant of the machine we just put the CT on the power in cable.
6 hours ago, Hoops123 said:
Hi,
I am pretty sure that there are already solutions for this, but the short answer is YES, there are Modbus libraries for pretty much anything.
also, which will be the end destination of the data? if it is only for data collection purposes, dumping everything into a database could be a good approach I suggest using Influx DB/Telegraf (Its free and open source self-hosted, or you could pay and use the cloud):
Modbus Master Monitoring | Influx Data
you could install a Telegraf client on each machine and configure the output plugin to dump the data into a single database.
other solution, could be use Node-red + the Modbus nodes, you could create a virtual Master to read from the physical slaves, then send the data over Modbus TCP to the real Master:
Node-RED (nodered.org).
Also, open source and easier since is No code" interface".
The only caveat using either of those suggestions is that you need to have the software running as services on starting in each computer.
Thanks for your replies!
The part number is WND-WR-MB from a company called Continental Control Systems.
Maybe this is a sign of things to come. I opened a chatGPT account and asked it to write the C# code and it did. Just starting to test it now.
Let me know if it works, I have asked chat GPT for some stuff, but I don't really trust its results. at least as something that I could copy/paste and it work at the first try but if you know what you are doing then yes, with some tweaks you could make it work.
btw Ising Node-Red it should look like something like this:
the buffer-parser node just in case that you need to swap bytes or something like that.
The beauty of Node-Red is that runs in the background, and you access thru a web interface.
