Hello PLC Community!
This DEMO  .vlp file suggests a very powerful HMI  animation  graphics "Fusion" concept.  It's using the "real time" HMI sensor data to form "true to scale" and "live" representations of an animated graphical display of complex industrial machinery and processes.
An example of such would be an overhead gantry crane tracking its precise X and Y movements including its Z cable payout. All with sensor data accurate HMI animations. Others may be an X,Y laser cutting machine or large metal presses, etc.
What I like about the fusion graphics is, for example in the demo, the elevator lift piston position is precisely where the elevator actually is!
The elevator doors for example, if were "stuck" half way open,  this would also be reflected in the real time graphics. What you see in the HMI display is in "real time" what it is. This is the awesome power of using the fused graphics.
It is my quest to now form a dedicated HMI fusion graphic engines (FB's) library.  Simple modifications to the existing bar graphs can be made by exposing  the "hooks" as "user coding variables" to programmatically control the arrow UP and arrow Down directions for example.
Other coding designs would be to incorporate multi point "indexing" of the existing bar graphs and linking capabilities.
I would think that such a library offering of an HMI animated graphics package for the PLC market would be a highly desired marketing feature.
I hope to hear from the Unitronics software coders their thoughts and exploration into this concept.
Elavator V.85.vlp
Edited by RickL
revised V.85
