MVP 2022 Ausman Posted July 1 MVP 2022 Report Share Posted July 1 Hi all, over the years I've had varying success with different Virtual Serial to IP programs. Some of the supposedly "modern" ones don't want to play properly, and the old faithful still seems to be the most reliable for me, which is USR's VCOM 3.4.1.0. Wondering what other forum members have as their favourite/one that works reliably? cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted July 2 MVP 2022 Report Share Posted July 2 Did you intend to post this here? Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted July 2 Author MVP 2022 Report Share Posted July 2 Hi Flex, after lots of consideration because it's such a broad "overview" type question, I felt this was the best forum area to put it up. Feel free to move it! And as an aside, in trialling a few more programs on my main PC, I've once again encountered the annoying habit of many serial related programs totally over-writing existing serial drivers, even including the one used for the native serial port, without any sort of permission asked etc. I couldn't understand why some new cables I'd made weren't working on Com1. After meter checking again and finding them seemingly perfect, I was thinking that perhaps the pre-moulded plug I was using at one end was missing/had something internally that wasn't obvious with just a continuity check. But I finally tried a known good pre-existing one and up popped the same "comm error". Grrrrr. 😠 Uninstalled the offenders and the drivers windoze had stored deeply away, and I was eventually back in business. But it was very annoying. cheers, Aus Quote Link to comment Share on other sites More sharing options...
