JZ20-J-T40 Ethernet communication with SCADA
Hi,
I'm using Unitronics PLC JZ20-J-T40, and ZView SCADA.
I have successfully downloaded my program into PLC, and tested communication via usb (Serial), and via Ethernet (MJ20-ET1). It's all working properly.
Problem begins when i try to connect my PLC to scada PC.
With USB everything is working normally, but it's not an option for me to work with usb connection.
I want to work with Ethernet communication between PLC and SCADA.
What should i do to make it work?
Regards
Nikola Ljubinkovic
Hi,
I contacted Zivan company who is  the supplier of the Zview.
In order to support Jazz Ethernet please try the following:
1. Change the attached file drvlazz.txt to drvlazz.dll and copy it to Zview\bin
2. Change the attached file Zview.txt to Zview.exe and replace in Zview\bin
3. in the project you should select as attached picture.
ZView.txt
drvjazz.txt
Hi,
I did everything like you said, but it's still not working.
I have 1 Unitronics V130-J-TR20 PLC and 2 Unitronics PLC-s Jazz JZ20-J-T40.
When I set everything like you said, Jazz PLC is working properly, but V130 doesn't .
In attachment i have sent pictures with my settings for V130 and JZ20 PLC, on ZView SCADA.
Just to make it clear, I can establish communication with only one of the two different PLC-s, but when i connect them together, one of them stops working.
Either Jazz is working, or V130, but together SCADA just says port inactive.
vuapp.ini
Also, I wanted to add this,
My SCADA license is this on the picture
I have seen that in order to connect PLC to SCADA I need to have specific driver for that PLC on my SCADA usb(License).
When I purchased license, and connected it to V130 (Vision) via Ethernet, everything was working normally, but when i tried to connect my other Jazz PLC, that is when problems has began.
I contacted you, and you give me driver to connect to Jazz, I pasted it like you said.
Then I realized that Zview SCADA (From Zivan) doesn't have that kind of option (Or in my case).
Anyway, this is what has happened.
V130 has worked normally, until I put this driver you have gave me.
Now eider Jazz is working, or Vision V130.
It seems like Zview SCADA can only use one of the drivers for connecting PLC to SCADA.
When connecting, on the very beginning, SCADA chooses one of the drivers, and that driver is either for Jazz or Vision.
When it has successfully connected to one of the PLCs using one of the drivers, it just won't connect to the other one using the other driver.
It is a big problem for me, is there a way to change some settings on zView SCADA in order to use both of the drivers I have, or there is some other solution?
Regards
Nikola Ljubinkovic
