Sign in to follow this
nkwai
Vision 130 screen problem
Hello, I have a problem with a V130, some horizontal display lines just disappeared (see attached picture).
I still haven't tried anything because I thought it would be best to ask here first if someone maybe knows the solution. The only idea I have is to open it (like when adding ports) and clean the contacts.
Any help will be appreciated.
Regards
I would first be checking the ribbon connector insertion.  It is very easy to not push it in far enough before reclamping. If cards have been added then it is the likely problem, as you have to undo it for some add-ons.
Owing to it being fiddly and awkward it can seem to bottom out, but it isn't in enough.  But use care in any manipulations.
Undo the case rear and then carefully lift out the "first" pcb by holding the connectors.
Check out the install instructions here:  https://myzone-kza3sadj.netdna-ssl.com/wp-content/uploads/2015/12/installation-guide-V100-17-RS4X_ET2_S-ET2_17-PB1.pdf
They will give you the details about the ribbon, bottom of page 2.
Hopefully that will be the issue.  Pls advise back.
cheers,
Aus
Thank you for your answer.
Opened the PLC today, cleaned all the contacts, double checked the ribbon, but the display is still the same.
Hi, it's well over warranty, it think it's around 9 years old now. Thankfully there is a PC near, and the PLC is connected to the network, so I using Remote access for now. I'll contact the representative for my country to see if it is possible to repair it, or a replacement is needed.
Register a new account
Sign in
