t0r3r0s Posted January 15, 2018 Report Share Posted January 15, 2018 Greeatings . I need help , i make one subrutine and i cant restart my timer in this subrutine, in attach i set my code for subroutine if someone can set for me timer on pleace that can help me or say me how can i make it. What i need , when i run my subroutine i activate my timer if timer si on i reset all my output and set Stop_filtration_top, this bit is important to me , whit this bit i call my second subroutine and if this second subroutin is finish i restart Stop_filtration_top and can back to first routine filtration.vlx Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 15, 2018 MVP 2023 Report Share Posted January 15, 2018 You need to attach your entire project. You describe calling multiple subroutines, but only attached an export of one. We have no idea if you are doing the calling correctly. Please post your code. Joe T. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted January 16, 2018 Author Report Share Posted January 16, 2018 8 hours ago, Joe Tauser said: You need to attach your entire project. You describe calling multiple subroutines, but only attached an export of one. We have no idea if you are doing the calling correctly. Please post your code. Joe T. ok i send you I have one more question , subroutin are always call or only when line is on ? Euroaquaing.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted January 16, 2018 MVP 2023 Report Share Posted January 16, 2018 I haven't looked at your program. Something FYI. In case you don't know, Visilogic has an annoying quirk....when in online mode it shows elements of an uncalled sub in red (powered). This can be very confusing. There are many solutions to this, the best I know of from another forum member (can't remember who...sorry) was to set up a simple count at the top of each sub. If the count is progessing, the sub is active. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
Isakovic Posted January 17, 2018 Report Share Posted January 17, 2018 I couldn't find any reset coil elements for timers in ladder. Are you resetting it by not calling a subroutine? Someone correct me if I'm wrong, but I think that nets in subroutines won't get updated if subroutine is not called (so bits that were 1 when program last time passed through subroutine will remain 1). I find this not intuitive so I usually run through all routines from main and use bits as conditions. Maybe your program will work if you used reset coil for timer. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 17, 2018 MVP 2023 Report Share Posted January 17, 2018 8 hours ago, Isakovic said: nets in subroutines won't get updated if subroutine is not called (so bits that were 1 when program last time passed through subroutine will remain 1) Yes this is true. That's why it's not good practice to have conditional calls to subroutines except in special circumstances. Avoid that whenever possible. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted January 20, 2018 Author Report Share Posted January 20, 2018 Problem resolved Quote Link to comment Share on other sites More sharing options...
