Marin Posted March 5, 2019 Report Share Posted March 5, 2019 Hi There! I have been trying to set up simple timer with hour:minutes and day of the week selection. So, everything works great with time houres and minutes, i can set them via HMI and they work ok........but when i try to import day of week, in HMI it shows up and i can chose between MON, TUE....SUN.....but everytime after i set desired day and press enter it returns to SUN......also, is same if i chose day of month, everytime i chose between 31 days it return to 1..... I checked manual, help and forum but i could not find solution, so if someone have time, programm is attached. thanks!!! timer.U90 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 7, 2019 MVP 2023 Report Share Posted March 7, 2019 HI Marin, not enough time at present to completely assess your program. But if you look in the Help/Sample U90 projects and find Bank open hours.U90 that should point you in the right direction. Load that into your plc, go online and monitor what happens as you step through things. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Marin Posted March 8, 2019 Author Report Share Posted March 8, 2019 Hi! I tried that same example and i have same issue........so setting of time is ok, but when i try to set day, no matther which i chose after confirming (enter) it always set to SUN Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted March 8, 2019 MVP 2023 Report Share Posted March 8, 2019 I have the same issue.. As i see for time keypad entry checkbox is active. Maybe problem is in selected area - checkbox is not active for day and month? This question is to creators. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted March 9, 2019 MVP 2023 Report Share Posted March 9, 2019 Send your application to support@unitronics.com and they'll have an official look at your problem. Joe T. Quote Link to comment Share on other sites More sharing options...
Marin Posted March 9, 2019 Author Report Share Posted March 9, 2019 Keypad entry is activated by defaultu probably and you can enter values, but they are not set when enter is pressed, but return to first.........also i tried with month and is same as with week. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted March 12, 2019 MVP 2023 Report Share Posted March 12, 2019 I've made some time to have a little play with this. I set up an indirect day adjustment, and the associated MI adjusts to the correct amount to match what has been chosen by stepping through the screen using up/down and then +/-. However, upon pressing enter the display resets to SUN, but the MI remains correct at the chosen day. So it would appear that this On 3/9/2019 at 4:36 PM, Marin said: but they are not set when enter is pressed, is not true in some ways. I've never used this facility and perhaps it is the way it is meant to work, in that you use the MI somewhere else, and the "SUN" is only the "default start point" for doing the action on the screen. I've got to give up now for some zzzzz. Maybe in another few days I'll have a further peek. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Marin Posted March 14, 2019 Author Report Share Posted March 14, 2019 That could be the problem.......either it is done that way for some reason..... So after you confirm it, it wrotes right value to MI, but lcd returns to SUN or 1 if you take months fb. But anway it can be a software issue, as if there is some "logic" behind that, it would be same for time setting? Quote Link to comment Share on other sites More sharing options...
