HexMan Posted July 11, 2019 Report Share Posted July 11, 2019 Hi guys! I am trying to install the latest version of VisiLogic, but it is not possible in my Windows 10 x64 (PRO) laptop. Trying in a VM with Windows 7 works fine... Any idea? Quote Link to comment Share on other sites More sharing options...
DanT Posted July 11, 2019 Report Share Posted July 11, 2019 Hi; Been there , done that. This is a Windows related issue. There is an install shield file that has information in it causing the problem, and has to be moved or deleted. Here is a solution: CAUTION : I Take NO Responsibility for anything that happens ( good or bad)!!!!! Local Administrator privileges may be necessary. KNOW what you are doing! Open C:\Program Files (x86)\InstallShield Installation Information There are a few or many very oddly named folders e.g. {12AB95C7-C72D-4CF5-9B6D-7452DF048C56} Starting at the top, click on the folder to open it: Each folder has a group of files. Look for the file : Setup.ini Double click to open the file or open the file in Notepad ( Notepad ONLY, this is a simple Text File) Top Line [Startup] 2nd line AppName= If the App name is NOT VisiLogic, close Notepad ( DO NOT do a Save or Save As) Move on the next folder If the Appname= is VisiLogic, Close Notepad Back out of that folder, Cut the Folder and Paste it into the Downloads Folder -- Just a safe place to put it for now. Also Rename the Folder and ADD - VisiLogic Restart the VisiLogic Installation, and ( fingers crossed ) it should go smoothly. You can also run a registry cleanup program later to locate and delete unused registry entries. Dant 2 Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 12, 2019 MVP 2023 Report Share Posted July 12, 2019 OK Dan, I have to ask! How many times did you bang your head on the wall during finding this answer? Good stuff. cheers, Aus Quote Link to comment Share on other sites More sharing options...
HexMan Posted July 12, 2019 Author Report Share Posted July 12, 2019 Hello Guys! First of all... DanT, thanks! The solution works ok in this case! AMAZING. The problem is with the previus version, I don´t know why, but is impossible to unistall. Quote Link to comment Share on other sites More sharing options...
DanT Posted July 12, 2019 Report Share Posted July 12, 2019 Hi Aus; Too Many times, and a bit of research, registry editing(hacking), and help from other sources. There is a registry entry that has to be removed/bypassed , but this is a safer way. Dant Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 13, 2019 MVP 2023 Report Share Posted July 13, 2019 On 7/12/2019 at 4:28 PM, HexMan said: but is impossible to unistall I know it's a bit late now, but a thing to remember for the future is the use of Revo Uninstaller. It often solves incomplete uninstall problems. I always use the portable type, free/$ versions available here: https://www.revouninstaller.com/revo-uninstaller-free-download/ cheers, Aus Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 14, 2019 Report Share Posted July 14, 2019 Hi All, Solution DanT suggested is explained in Unitronics Help Center Article (Nov. 2017). When you look for solutions, please visit and search not only in Forum topics, but in Unitronics Help Center Articles too. Link: https://support.unitronics.com/ There are many available articles. If you have solution to share, tell us know and we will add it to Articles. B.R. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted July 16, 2019 Report Share Posted July 16, 2019 On 7/14/2019 at 1:37 AM, Ausman said: I know it's a bit late now, but a thing to remember for the future is the use of Revo Uninstaller. It often solves incomplete uninstall problems. I always use the portable type, free/$ versions available here: https://www.revouninstaller.com/revo-uninstaller-free-download/ cheers, Aus I'm going to check this out--thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted July 16, 2019 MVP 2023 Report Share Posted July 16, 2019 11 hours ago, Cara Bereck Levy said: I'm going to check this out--thanks! I'd love to take all the credit for this suggestion, but it has been mentioned by lots of people over time. 🤓 cheers, Aus Quote Link to comment Share on other sites More sharing options...
