corneln Posted April 24, 2020 Report Share Posted April 24, 2020 Hello i need help from the community in solving one need. we are using a lot of V130/ 350 / 570 / 700 plc's, and many of them have barcode scanners and barcode printers. until now, all of them have been connected to scanner and printer over RS232. all the barcode printers are Zebra (ZM400/ ZT 230). on RS 232, the printing works great. we would like to move the printer from RS232 to Ethernet, but we don't know exactly what would be the settings needed on the ethernet side (port/socket/protocol) and on the printing command. if anyone can share a back-up... find in the attachment the current setting for rs232 set-up and printing that we currently use. backup.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted April 24, 2020 MVP 2023 Report Share Posted April 24, 2020 You post your topic on UniLogic Software forum section, do you also need to shift to Unesrteam hardware? If you stay at Visilogic - please found V700 Ethernet printer sample project in Help/Examples/Version900/Porject examples/Communication/Ehternet directory. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted April 24, 2020 MVP 2023 Report Share Posted April 24, 2020 Moved to correct forum. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 25, 2020 MVP 2023 Report Share Posted April 25, 2020 This is in the Vision examples, which may or may not be helpful. Joe T. V350_Ethernet_printer.vlp Quote Link to comment Share on other sites More sharing options...
corneln Posted April 26, 2020 Author Report Share Posted April 26, 2020 Hello Kratmel so, from what i see in the help file, the message sent to the printer by ethernet com will be exactly the same as for rs232 com, just the connection parameters need to be modified. did i understand good? Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted April 26, 2020 MVP 2023 Report Share Posted April 26, 2020 Yes, it is the same. Main problem is to manage correct network parameter on Zebra printer via Zebra software. You can print internal Network Configuration Label If you need to use internal Zebra font, simple grafic or generate bar code please see link to online lable generator in my topic Quote Link to comment Share on other sites More sharing options...
