benito.carrasco Posted July 31 Report Share Posted July 31 My question is about JAZZ PLCs if there is a way to back up the program memory. I would like to know if it is possible to save a backup copy of the program so that, if the PLC breaks down, we can replace it and restore both the program and the memory quickly and efficiently. Link to comment Share on other sites More sharing options...
Felixs Posted August 11 Report Share Posted August 11 Yes, you can upload the program to the computer using the U90 ladder software and the usb cable, I did that a few weeks ago to backup a Jazz PLC Link to comment Share on other sites More sharing options...
DanT Posted August 12 Report Share Posted August 12 Hi; Backing up a Program in a PLC , if the program is not password protected is easy - upload - to U90 ladder and save to a file. Backing up the MI, MB and other PLC Memory current values is another story. U90 appears NOT to have a method of backing up the current live PLC values. In, Out, MB, MI, Timers, SI, SB. etc. The only way I can think of is to have PDF printer on your PC, then go online with the PLC, Display the OPerande and do a print screen to PDF slow and can be a pain. Restoring would be to know the important values in the program to resore and look them up in the PDF pages saved and manually enter them when in PLC Online Mode. Yep - another pain. U90 was the original Unitronics Ladder programming software and has it limits - but the M90, M91 and JAZZ series thive on it. DanT Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 12 MVP 2023 Report Share Posted August 12 On 7/31/2024 at 2:28 PM, benito.carrasco said: if it is possible to save a backup copy of the program so that, if the PLC breaks down, we can replace it and restore both the program and the memory quickly and efficiently. For cloning JAZZ application you can use MJ20-MEM1 module. Please read https://cdn.i-pulse.nl/isotron/production/products/1474/datasheet-unitronics-mj20-mem1.pdf The Program Cloner enables you to copy applications between Jazz™ OPLCs™. You plug the Cloner into the jack of a Jazz OPLC and then use Info Mode to: - Copy the complete application, including the PLC Ladder program, HMI application, and OS into the Cloner. In addition, you can also copy certain current application values. You can find a list of these values in the Jazz user guide. - Plug the Cloner into another Jazz OPLC and download the complete application You can ask your local distributor about the possibility of purchasing such a module and ask if it is compatible with your model of Jazz PLC. You can also ask about the capabilities of this module via email --- support@unitronics.com Link to comment Share on other sites More sharing options...
Pavel_setnicar Posted August 13 Report Share Posted August 13 HI all May I use this topic to ask about Samba controllers, how can I clone program from one to another since I have perfectly tuned PID (after many PITA) and now I want to do a spare controller with already tuned PID. Is there a way to dothis? Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted August 13 MVP 2023 Report Share Posted August 13 Which Samba? And do you have the source .vlp file? Link to comment Share on other sites More sharing options...
AlexUT Posted August 14 Report Share Posted August 14 1.You can create UniDownloader file, which may be downloaded to PLC by UniDownloader. This file may include everything, but no memory content. 2. To backup and then restore memory content, you can follow HelpDesk article: Vision PLC battery change without losing data https://support.unitronics.com/index.php?/selfhelp/view-Itarticle/vision-plc-battery-change-without-losing-data allow to save memory content in Excel file. *Bear in mind that memory content changes. PID parameters are partially static and partially dynamic. As well, some memory content is changed during PLC operation - MIs, etc. SAMBA related questions publich in SAMBA topic. Link to comment Share on other sites More sharing options...
Pavel_setnicar Posted August 14 Report Share Posted August 14 Yes I have .vlp file (Iwrote it). I will try sugested. Thank you. Link to comment Share on other sites More sharing options...
Pavel_setnicar Posted August 14 Report Share Posted August 14 Oh ja,Samba 35-J-T20 Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted August 14 MVP 2023 Report Share Posted August 14 I can add that I successfully copied the PID settings of the controller based on Samba and my customers continue to do this for their products. To save the settings, it is convenient to use the function Export PLC operands to a text file (Visilogic Communication menu). And then for the next controller, load these settings with the function Import PLC operands from a text file. P.S.Now it is a good tradition to save the project file in the last working version and the text file (with the same name) of the operands that were in the configured controller. It is also good to archive them together to keep a copy. 1 Link to comment Share on other sites More sharing options...
Pavel_setnicar Posted August 15 Report Share Posted August 15 Ja, after many hours tuning the PID parameters, it is good to have them backedand not worry about when new controller is needed. Link to comment Share on other sites More sharing options...
