Martin1 Posted December 12, 2012 Report Share Posted December 12, 2012 I am having an issue saving a project. Any time I go to save, it pops up error code 464 "illegal project name". What is causing this? I am not using any illegal characters! I uninstalled visilogic twice but still the same:( P.S I recently got a new PC (X64bit) Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted December 13, 2012 Report Share Posted December 13, 2012 Hello Sir, As far as we checked, all Unitronics software and utilities are able to work on WIN7 64bit machines but we didn't try to work day by day with x64 PC and we are still checking this issue with our R&D. So meanwhile as it shows in the system requirement, our official position is related to 32bit PC's only. Please note: Microsoft UAC requires that you execute the installation using the "Run as Administrator" command. Microsoft introduced the UAC to provide users with more security. If you facing some problems with VisiLogic, please open the software's as "administrator" (Right mouse click). If VisiLogic opened properly, Go to the properties of VisiLogic shoutrcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. for more information please look at the attached file. i hope it helps... Vista and Windows 7- Disabling UAC (User Account Control).pdf Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 13, 2012 MVP 2021 Report Share Posted December 13, 2012 I've had a similar error when trying to save a project into a folder that's nested too deep. If you're saving to a folder other than C:\Program Files\Unitronics\Unitronics VisiLogic_C\Applications\, then try saving the file there, or elsewhere that doesn't have too many sub-folders. Quote Link to comment Share on other sites More sharing options...
Saragani Posted December 13, 2012 Report Share Posted December 13, 2012 Flex727, it is not related to the deepness of the nesting, but actually to the length of the path. In windows, the path to the file must not exceed the 260 bytes. Quote Link to comment Share on other sites More sharing options...
Martin1 Posted December 14, 2012 Author Report Share Posted December 14, 2012 Thank you for that. I can now save my projects:) I was saving my projects to my dropbox folder with no problem but since I upgraded my PC it won't allow me any more. I've had a similar error when trying to save a project into a folder that's nested too deep. If you're saving to a folder other than C:\Program Files\Unitronics\Unitronics VisiLogic_C\Applications\, then try saving the file there, or elsewhere that doesn't have too many sub-folders. Quote Link to comment Share on other sites More sharing options...
