Dan555 Posted April 1, 2014 Report Share Posted April 1, 2014 Hi, I have been working with Unistream for a couple of months, and I can say that is a Interesting and competitive platform, but now I am stuck with something, the PLC don´t recognized the DOK, any DOK (2GB,4GB,8GB,16GB), I can’t Upgrade the PLC (It is necessary to use Unilogic 1.5). I tried to export the application to the DOK and there is an error, the DOK is not mounted. The DOK is formatted (FAT32) and empty, I tried with different CPU, with different DOK´s, but it dont works.The HMI don't recognized the DOK. Any Idea About That?. Thanks a lot from Mexico, Ing.González Jaimes Daniel, Sistemas de Control Autec, México D.F. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted April 10, 2014 Report Share Posted April 10, 2014 Hello Jaimes Daniel, We would like to have an online session with you. Please write to support@unitronics.com and state on what time you will be available. Quote Link to comment Share on other sites More sharing options...
facerq Posted August 19, 2014 Report Share Posted August 19, 2014 I'm having the same problem. I'm working with a USP-104-B10 and I cant update the firmware nor export the program. Tried with 3 different USB sticks all in fat32. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted February 18, 2015 Report Share Posted February 18, 2015 Hi all,Same problem with me.Panel is USP-104-B10 - we have 2 pieces of them - usb stick is not reckognized, and I can't transfer firmware files. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted February 19, 2015 Report Share Posted February 19, 2015 Hello, Finally, I managed to deal with this problem.Initially I tried one 8GB usb stick, and then one 4GB stick - negative result. After that, I split the 4GB stick in two partitions. The size of partition that worked for me after several trials is approx. 1.5GB and FAT32 file system. Regards, Plamen Gugulanov 1 Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 22, 2015 Report Share Posted February 22, 2015 Hi, I work with a 16GB partition USB Stick without a problem. Quote Link to comment Share on other sites More sharing options...
bpond Posted June 23, 2015 Report Share Posted June 23, 2015 I have the same problem with 8GB and 32GB SD cards. Is there an explanation for the error? When I plug a new, formatted or un-formatted SD card, go directly to the export screen and I get the DOK error. I have not tried with a USB stick. Also interesting is that when I try to export the program from UniLogic to a USB device, I get an error with an 8GB card that there was insufficient space on the device. I re-tried with a 32GB card and was successful, however the resulting file was only 212kB in size. Quote Link to comment Share on other sites More sharing options...
max_145 Posted September 16, 2015 Report Share Posted September 16, 2015 I have the same problem. I tried to update the firmware of my unistream controller with usb memory stick. The panel does not recognize the usb memory stick. I tried 2 different memory sticks with a capacity of 8 GB formatted in fat32. Both did not work. Is there anything to take care of? Do the memory sticks need special formatting to be recognized by the unistream controller? I also tried to save the application to the dok (via uni apps), to crosscheck if the usb memory stick is recognized. But i always got the error "DOK COULD NOT BE FOUND" Any Ideas? Quote Link to comment Share on other sites More sharing options...
AjaS Posted June 11, 2019 Report Share Posted June 11, 2019 Hi all, can anyone share how to solve it, please? Thanks Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 11, 2019 Report Share Posted June 11, 2019 Hi AjaS, There is a lot of time pass since last post. Can you explain your problem with more details? - SD/Disk on key size. - Number of partitions. - Partitions format. - UniLogic version you use. - Windows version you use. - Does IT department limit PC access to only for sertified by IP SD/Disk on key? - Sequence of operations you doing. - At what step and what error appear? Quote Link to comment Share on other sites More sharing options...
AjaS Posted June 11, 2019 Report Share Posted June 11, 2019 4 minutes ago, AlexUT said: Hi AjaS, There is a lot of time pass since last post. Can you explain your problem with more details? - SD/Disk on key size. 16 GB, 8 GB, 4 GB all blank, formatted before use - Number of partitions. 1024,4096 - Partitions format. all FAT32 - UniLogic version you use. 1.25 rev 48 in one PLC that works. Now, I wanted to download this project to never used PLC (the same type) version 1.23 rev 40. It asked for update. - Windows version you use. VM of Win 7 Enterprise, service pack 1 - Does IT department limit PC access to only for sertified by IP SD/Disk on key? no limitation - Sequence of operations you doing. 1. Click Firmware Manager to locate all firmware files on your PC. 2.Chosen firmware Copy to DOK (already blank and formatted). It offers "Save Firmware Files to USB device" 3. It takes a while and it is saved to DOK: "The firmware files were successfully copied to USB stick. Plug the stick to UniStream USB port, open UniApps->Upgrades and select upgrade PLC". Then I insert the USB to USB host. - At what step and what error appear? Then HMI/PLC screen -> Upgrades-> System-> Upgrade PLC (forced and also unforced), error: "The PLC upgrades do not match or could not be found. Please verify that required files are available and try again" Quote Link to comment Share on other sites More sharing options...
AjaS Posted June 11, 2019 Report Share Posted June 11, 2019 It took 5 different USBs with range 4GB to 16GB. I followed the same procedure, step by step. The USB that worked was ANOTHER FAT 32 16GB but with 8,168 partitions. I have no idea why it has decided to work this time... Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 11, 2019 Report Share Posted June 11, 2019 AjaS, There may be number of conditions leading to problems with SD/Disk on key mount and read at PC and UniStream PLC. *This example processed with 8 GB SD card and SD to USB adapter *If you have important files at SD/Disk on key - make backup. 1. If use Virtual Machine. Please check that selected USB port is linked to this VM 2. Open DOS prompt (Administrative) at VM. 3. Run "diskpart" 4. Enter "list disk". This command will list disks at your Windows VM. DISKPART> list disk Disk ### Status Size Free Dyn Gpt -------- ------------- ------- ------- --- --- Disk 0 Online 465 GB 0 B Disk 1 Online 931 GB 0 B For example, you have 2 disks, as listed. 5. Insert your SD/Disk on key to linked to this VM USB or SD slot. 6. Enter "list disk". This command will list disks at your Windows VM. DISKPART> list disk Disk ### Status Size Free Dyn Gpt -------- ------------- ------- ------- --- --- Disk 0 Online 465 GB 0 B Disk 1 Online 931 GB 0 B * Disk 2 Online 7580 MB 0 B New disk should be listed. If new disk is not listed, than there is a problem you should solve by IT. 7. Suppose that a new disk listed. Enter "select disk 2". 8. Enter "list partition" DISKPART> list partition Partition ### Type Size Offset ------------- ---------------- ------- ------- * Partition 1 Primary 7580 MB 0 B Offset should not be 0 B 9. Enter "clean" DISKPART> clean This will clean partition information from selected disk. TAKE CARE TO SELECT new listed disk. EVERYTHING will be deleted from selected disk. This will take some time to prosess. Be patient. 10. When finished, message will be displayed: DISKPART> clean DiskPart succeeded in cleaning the disk. 11. Enter "list disk". DISKPART> list disk Disk ### Status Size Free Dyn Gpt -------- ------------- ------- ------- --- --- Disk 0 Online 465 GB 0 B Disk 1 Online 931 GB 0 B * Disk 2 Online 7580 MB 0 B New disk should be listed and marked by *. 12. Suppose that a new disk listed. Enter "select disk 2". 13. Enter "list partition" DISKPART> list partition There are no partitions on this disk to show. 14. Enter "create partition primary" DISKPART> create partition primary DiskPart succeeded in creating the specified partition. 15. Enter "list partition" DISKPART> list partition Partition ### Type Size Offset ------------- ---------------- ------- ------- * Partition 1 Primary 7579 MB 1024 KB Offset should not be 0 B 16. Enter "detail partition" DISKPART> detail partition Partition 1 Type : 06 Hidden: No Active: No Offset in Bytes: 1048576 Volume ### Ltr Label Fs Type Size Status Info ---------- --- ----------- ----- ---------- ------- --------- -------- * Volume 4 E RAW Removable 7579 MB Healthy File system is RAW (not formatted) 17. Format new disk from VM Windows File Explorer with cluster size 4096. 18. Enter "detail partition" DISKPART> detail partition Partition 1 Type : 0B Hidden: No Active: No Offset in Bytes: 1048576 Volume ### Ltr Label Fs Type Size Status Info ---------- --- ----------- ----- ---------- ------- --------- -------- * Volume 4 E FAT32 Removable 7579 MB Healthy File system is FAT32 19. Enter "exit"to close diskpart. DISKPART> exit Leaving DiskPart... C:\> 20. You can close DOS prompt. 21. Eject SD/Disk on key from OS and detach it from PC USB port. 22. Insert SD/Disk on key to SAD slot or to USB connector at PLC. 23. Go to UniApps at PLC. 24. Select Memory->File Browser. 25. For SD card you can see list of default directories. 26. For Dosk on key DOK you can see list of files or directories, if presented. Hope this helps to make SD/Disk on key working. B.R. Quote Link to comment Share on other sites More sharing options...
MarcinPL Posted February 19, 2020 Report Share Posted February 19, 2020 AlexUT Thank You it works. :). I don't know why but work. Quote Link to comment Share on other sites More sharing options...
