greml1n Posted July 3, 2014 Report Share Posted July 3, 2014 My less than graceful great dane got his foot caught up with my communication cable to my UniStream. Needless to say he pulled the cable out of the controller along with the jack that the cable plugs into so the USB device connection is screwed. I'm trying to connect to the UniStream with an Ethernet cable and am having no luck. I plug an Ethernet cable into my laptop and into UniStream and port lights do light up. I went into UniApps to obtain the IP address to enter into PLC-PC communications to connect using Ethernet and I am having no luck. What am I missing? Also, is it possible to send the panel back for repair of the USB device jack? This panel is brand new, I didn't even pull the plastic of the screen yet 1 Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted July 6, 2014 Report Share Posted July 6, 2014 Hi, First of all, let's talk about Ethernet communication. In your case, hence connecting the PLC to PC directly, both Ip addresses should be of the same domain. So, if your PLC's IP address is 192.168.1.2, then your PC should have a similar address such as 192.168.1.3. In most cases it will make more sense to first see what is the IP address assigned to your PC, and then change the address in the PLC accordingly. To check the IP address on your PC (in Windows) do the following: 1. Go to the command prompt - the easiest way to do it is to type "command prompt" in Windows search line and select the first program that pops up. 2. Type "ipconfig" in the command line and press enter. 3. A list of numbers and texts will appear. Your PC IP address will next to the text "IPv4 Address". Regarding the repair of your PLC, please contact your supplier for repair information. Quote Link to comment Share on other sites More sharing options...
greml1n Posted July 6, 2014 Author Report Share Posted July 6, 2014 I still cant connect the PLC directly to my laptop with an Ethernet cable. I am however able to connect when I plug the Unistream into my router. Im obviously still missing something Quote Link to comment Share on other sites More sharing options...
lawry Posted July 7, 2014 Report Share Posted July 7, 2014 For direct connection, use a crossed cable Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted July 7, 2014 Report Share Posted July 7, 2014 I still cant connect the PLC directly to my laptop with an Ethernet cable. I am however able to connect when I plug the Unistream into my router. Im obviously still missing something Are you familiar process of defining a static IP address in your PC? If not, this is a step you should know. To communicate between two (or more) devices over Ethernet, they must be configured to be in the same network. In most cases (connecting to the internet for example), the modem/router is "deciding" on what address the network should be. It assigns an IP address to the PC using a system called DHCP. For connecting directly directly between PC and PLC, you need to manually define the network parameters. Here is how to do it: 1. From the search bar in windows start menu, type "view network connections" and select the first result. 2. From the window that was just opened, right click on the icon named "Local Area Connection", and select "Properties" 3. From the Properties window, double click on "Internet Protocol Version 4 (TCP/IPv4)". 4. Select "Use the Following IP address", and type the parameters of the network. in "Subnet mask" type 255.255.255.0 and in "default gateway" type 192.168.1.1 (as defined in the Unistream). For the IP address, select a different one like 192.168.1.4. 5. Press OK twice to close the two windows. You should now be able to communicate between PC and PLC. Please note: you must revert back the changes you made to be able to use the internet again, hence changing the state back to "Obtain IP address automatically". I also recommend reading some more about Ethernet networks and communication. It can prove most useful in the field of industrial automation (and others). I attached a short PDF from Visilogic help file giving some background on Ethernet networking. Ethernet.pdf 1 Quote Link to comment Share on other sites More sharing options...
Juan Manuel Posted January 31, 2017 Report Share Posted January 31, 2017 How I find the PLC Name and tcp port to conect my 7" Panel and PLC to Unitronics android APP? Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 31, 2017 Report Share Posted January 31, 2017 which android App? Quote Link to comment Share on other sites More sharing options...
Will0101 Posted May 8 Report Share Posted May 8 Anyone know the answer to this? How I find the PLC Name and tcp port to conect my 7" Panel and PLC to Unitronics android APP? Quote Quote Link to comment Share on other sites More sharing options...
