VasilPopov Posted August 28, 2014 Report Share Posted August 28, 2014 Hello! Another one topic PLC/E-mail. Unfortunately, I'm not able to copy with the problems. I use the ladder from Example (of course). In CMD I write "telnet pop.gmail.com 25" and I can see the protocol type used by the server. After that i tape "pin pop.gmail.com" and see the IP address of the server. The first change that I make in the ladder is IP in "TCP/IP - Tcp connect" block. The new IP is the same as IP address of the server. The second change is in the "E-mail" block. "From:" e-mail is Support@unitronics.com and the receiving e-mail is "..........gmail.com". When I press "connect" in HMI the system is able to connect. However, when I press "Send E-mail" there are two mistakes: "The server cannot receive data (DATA mode error)" and "From address format incorrect " I have tried many settings but non of them was workable. Please, give me an advise where might be the mistake! Quote Link to comment Share on other sites More sharing options...
AZ1975 Posted August 31, 2014 Report Share Posted August 31, 2014 Check port 25 open Tomorrow i can send you my prog with email working Quote Link to comment Share on other sites More sharing options...
VasilPopov Posted September 1, 2014 Author Report Share Posted September 1, 2014 I will appreciate if you send the the program. I will have a chance to compare the ladders. Quote Link to comment Share on other sites More sharing options...
Martin1 Posted September 2, 2014 Report Share Posted September 2, 2014 Hi AZ1975, Would it be possibe to send be your prog to me too? I too are having issues sending email. Thanks Martin Quote Link to comment Share on other sites More sharing options...
AZ1975 Posted September 4, 2014 Report Share Posted September 4, 2014 Hi to all, i was a few days off the office, i'll send you a pdf printing of the program Quote Link to comment Share on other sites More sharing options...
AZ1975 Posted September 4, 2014 Report Share Posted September 4, 2014 As I promised I attached two examples and some explanations. Enjoy it AZ1975 VisiLogic Project EMAIL1.pdf VisiLogic Project EMAIL2.pdf THE ULTIMATE EMAIL BIBLE.pdf Quote Link to comment Share on other sites More sharing options...
VasilPopov Posted September 5, 2014 Author Report Share Posted September 5, 2014 Thank you! What do you mean using a description in "The ultimate email bible" - "From: just a fantasy mail address" Quote Link to comment Share on other sites More sharing options...
AZ1975 Posted September 5, 2014 Report Share Posted September 5, 2014 It means that you don't have an active mail acount, try anyname@domain.com Quote Link to comment Share on other sites More sharing options...
uviteru Posted April 17, 2017 Report Share Posted April 17, 2017 Were you ever able to get the error you encountered to go away? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 17, 2017 MVP 2021 Report Share Posted April 17, 2017 1 hour ago, uviteru said: Were you ever able to get the error you encountered to go away? This is an old thread. Are you having a problem? Joe T. Quote Link to comment Share on other sites More sharing options...
uviteru Posted April 17, 2017 Report Share Posted April 17, 2017 2 hours ago, Joe Tauser said: This is an old thread. Are you having a problem? Joe T. Yes, My original problem was similar to this one, but I have since been able to send email. However, it is not consistent. Many times I get an error about there being an issue with my password, other times, as soon as the 'send email' bit goes true, it closes the socket connection for some reason. I can try to send an email over and over again and get very inconsistent behavior. I am using gmx over port 587. I posted a new topic about it here, But i hadn't gotten any bites yet, so I was looking around at other posts. Quote Link to comment Share on other sites More sharing options...
