Hannari Posted April 13, 2015 Report Share Posted April 13, 2015 Hi, I am wondering how to send two or more SDOs, one after the other. In attachment is a image of how I have been trying to do it. It awys just sends the first one in the network. I have tried putting them in series, parallel and in different rungs. I realize that the setup i have is not working out because, while the first one is sending then the "SDO in progress bit" goes high and then it skips the other one. Is there an easy way of doing this? Some thing that would trigger the second one to go of as soon as the first one is done. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted April 14, 2015 Report Share Posted April 14, 2015 Hello, Have you tried sequencing the sends? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 14, 2015 MVP 2021 Report Share Posted April 14, 2015 "You do not have permission to view this image" This is on s.pratt's post only. I can see Hannari's attachment fine. I encounter this problem often. Is it something on my end or yours? Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted April 16, 2015 Report Share Posted April 16, 2015 Hi Flex I think it is because of your new MVP status--the forum has about 8 billion permission settings, and I may have missed one of them when I set up the MVP category..I just tweaked them. Can you see it now? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 16, 2015 MVP 2021 Report Share Posted April 16, 2015 Yes! Thank you. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted April 16, 2015 Report Share Posted April 16, 2015 Quote Link to comment Share on other sites More sharing options...
