Turson Posted September 7, 2015 Report Share Posted September 7, 2015 Hi, I've tried to SSH into Unistream, which is asking for a password. What's the password? Can I do so? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Alexander Posted September 8, 2015 Report Share Posted September 8, 2015 The UniStream supports a VNC connection for remote operation but we are unfamiliar with SSH. Can you explain what you are trying to accomplish? Quote Link to comment Share on other sites More sharing options...
_MELLON_ Posted April 7, 2019 Report Share Posted April 7, 2019 Can i access PLC linux via ssh ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 7, 2019 MVP 2021 Report Share Posted April 7, 2019 No. The UniStream does not have a shell built into it that users can access. That would allow someone to create all kinds of havoc with the under-the-hood PLC file structure. The closest thing is the VNC server - I have not tried logging in from a VNC client on a linux box but it does work with a VNC client on an Android phone. Joe T. Quote Link to comment Share on other sites More sharing options...
_MELLON_ Posted April 9, 2019 Report Share Posted April 9, 2019 if you try to SSH to the PLC ip you will receive login prompt ... if this system runs linux this can help to menage C or Python scripting and brings lot of abilities for advanced user and application Quote Link to comment Share on other sites More sharing options...
mrivilla Posted January 29, 2021 Report Share Posted January 29, 2021 Hi I'm also interested... I was asking in the forum to install linux in the OPLC, and I see is already there Did you get how to access? I see many advantages using scripting in linux calling HTTP APIs, with curl POST/GET, etc. I have an old Vision350 color OPLC. thanks in advance. Marcos. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 29, 2021 MVP 2021 Report Share Posted January 29, 2021 The V350 is in a totally different product line. It does not have the same capabilities as the UniStream that is the topic of this thread. Quote Link to comment Share on other sites More sharing options...
