MVP 2021 Ausman Posted April 26, 2016 MVP 2021 Report Share Posted April 26, 2016 Hi all, attached is a little picture I've worked up of what I see as a simple but worthwhile addition to the Communication & OS Screen.......to include the name of the project in the PLC. Time for you all to play "spot the difference"! If added, this would save the tedious online interrogation via Info mode method when you need to check the name of the program to ensure a match. cheers, Aus AusProj.bmp 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 26, 2016 MVP 2021 Report Share Posted April 26, 2016 +1 on this! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted June 29, 2021 Author MVP 2021 Report Share Posted June 29, 2021 I'm giving this a bump as I still hate having to do so much to get into the name of the project that is actually in the plc. @Cara Bereck Levy Surely this isn't too hard to achieve. Would save a lot of hassle. cheers, Aus And here's the pic again without needing a download! Look carefully, young Luke. 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 30, 2021 MVP 2021 Report Share Posted June 30, 2021 17 hours ago, Ausman said: Look carefully, young Luke. Clever edit. And as I said before, +1 on this suggestion. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted July 11, 2021 Report Share Posted July 11, 2021 I'll check 🙂 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 13, 2021 Author MVP 2021 Report Share Posted July 13, 2021 Thanks Cara Quote Link to comment Share on other sites More sharing options...
