Rog Posted May 2, 2017 Report Share Posted May 2, 2017 I am kinda new to using visilogic and modbus. I just kinda need a better understanding of how to program using modbus to control this drive. Drive is allen bradley powerflex 4 Looking for a simple program to increase and decrease speed on the drive. Figuring on how the address part confuses me. Any example would help me understand little better Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 2, 2017 MVP 2021 Report Share Posted May 2, 2017 Look at the existing Modbus examples to see how the function blocks go together. It looks like you can talk to the drive using Modbus rtu via RS 485. Look at this document starting on page C-2 - http://literature.rockwellautomation.com/idc/groups/literature/documents/um/22a-um001_-en-e.pdf Have you done any type of Modbus before? It's not the simplest thing to do in Unitronics if you don't have a firm grasp on the Modbus protocol . You may want to look at my post at the bottom of this thread: http://forum.unitronics.com/topic/3582-modbus-rtu-and-danfoss/ Joe T. Quote Link to comment Share on other sites More sharing options...
Rog Posted May 2, 2017 Author Report Share Posted May 2, 2017 1 hour ago, Joe Tauser said: Look at the existing Modbus examples to see how the function blocks go together. It looks like you can talk to the drive using Modbus rtu via RS 485. Look at this document starting on page C-2 - http://literature.rockwellautomation.com/idc/groups/literature/documents/um/22a-um001_-en-e.pdf Have you done any type of Modbus before? It's not the simplest thing to do in Unitronics if you don't have a firm grasp on the Modbus protocol . You may want to look at my post at the bottom of this thread: http://forum.unitronics.com/topic/3582-modbus-rtu-and-danfoss/ Joe T. I have no knowledge of modbus. Besides watching the videos from Unitronics. Was wondering how the addresses are applied into the ladder logic. But I will look over, what you given me. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted May 2, 2017 MVP 2021 Report Share Posted May 2, 2017 For MODBUS addressing, go to the Help file in VisiLogic, click on the Contents tab, then expand the following: Communications / Communications FBs / MODBUS, then select any of the topics you need to read up on. For addressing from an external MODBUS master, select Slave Addressing. Quote Link to comment Share on other sites More sharing options...
John_R Posted May 3, 2017 Report Share Posted May 3, 2017 Rog, attached is an example of MODBUS control of an AB Powerflex,..... I cut this portion out of a program I did a year or so ago, parts of the logic may seem gibberish, like anything else , there are many ways to do the speed and/or run logic, but the key to the comms is is sending the right number to the right address, look at the parts where I send/receive with the MODBUS FB's. I added some comments in CAPS, pointing out some things to pay attention to...... also remember, the port on the V570 must be set to 485....... and of course, the baud in the com init, and node settings in the MODBUS FB have to match the VFD....... Hope this helps. Regards, JohnR powerflex VFD example.vlp Quote Link to comment Share on other sites More sharing options...
Rog Posted May 3, 2017 Author Report Share Posted May 3, 2017 27 minutes ago, JohnR said: Rog, attached is an example of MODBUS control of an AB Powerflex,..... I cut this portion out of a program I did a year or so ago, parts of the logic may seem gibberish, like anything else , there are many ways to do the speed and/or run logic, but the key to the comms is is sending the right number to the right address, look at the parts where I send/receive with the MODBUS FB's. I added some comments in CAPS, pointing out some things to pay attention to...... also remember, the port on the V570 must be set to 485....... and of course, the baud in the com init, and node settings in the MODBUS FB have to match the VFD....... Hope this helps. Regards, JohnR powerflex VFD example.vlp Thanks. It does bring in more perspective. Quote Link to comment Share on other sites More sharing options...
