rik decadt Posted February 18, 2018 Report Share Posted February 18, 2018 I'm using the version of UniLogic 1.22.13 . Where can I find the images of push buttons and lamps? I do not find that anywhere. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 19, 2018 MVP 2021 Report Share Posted February 19, 2018 C:\ProgramData\Unitronics\UniLogic\Data\UniPics\Buttons Joe T. Quote Link to comment Share on other sites More sharing options...
rik decadt Posted February 19, 2018 Author Report Share Posted February 19, 2018 Hey, under c: do I have program files than unitronics than unilogic or unilogic 1.21.51.0 and below that I would have to find data but that directory is not included Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 19, 2018 Report Share Posted February 19, 2018 No, not program files, but ProgramData (it is a hidden directory), but you should access the images from UniLogic itself. When you browse for an Image in UniLogic, then you have the UniPics in the quick shortcuts. See attached image: Quote Link to comment Share on other sites More sharing options...
Mario Sandoval Posted June 5, 2021 Report Share Posted June 5, 2021 i, I just have installed, las version of Unilogic, and do not appear the data folder, and in the software either. What can i do ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 6, 2021 MVP 2021 Report Share Posted June 6, 2021 Notice the path in Saragani's post above. "C:\Program Data" is a hidden folder, so if you don't have the properties in Explorer set to see hidden folders you won't be able to view it. When you're in an HMI screen the "Image Elements" toolbox appears. I'm guessing you've already got this far. It gets a little tricky when you click the "..." box under the Image property: I incorrectly stated in another post that UniPics don't get installed with UniLogic. You just have to know where to look for them. When you click on the "..." box, the open dialog appears. You then have to select "Unitronics UniLogic: Clicking the little ">" Expand Object thingy reveals the secret location: Joe T. Quote Link to comment Share on other sites More sharing options...
