I think you have the choice of 2 digital outputs from the IFM unit or 1 digital and 1 analog.
You need to decide how you are going to control.
You can use two digital and use the sensor settings to control levels or use the 4-20ma to give you a level and program the PLC to switch at specific levels.
If you use the analog you need to use an analog input on the PLC.
So the Digital outputs from the ifm sensor would run to the inputs on the PLC correct?
Craig, I deleted your repeat post.
All posts on this forum are subject to a moderator checking the post before it is made public, so if you think your post hasn't been registered correctly, it is just the innate delay waiting for a moderator to look at it.  Please keep this in mind.
cheers, Aus
If you're just looking for two specific levels then yes.  Program the unit for an output for each level you want an go back to my original answer - you can do this with two digital inputs.
