viscoelastic Posted January 16, 2019 Report Share Posted January 16, 2019 Is a way to have a speaker on the PLC to play *.wav files? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 16, 2019 MVP 2021 Report Share Posted January 16, 2019 Yes, re-wire that speaker to a computer. In all seriousness, I sincerely doubt it, but I eagerly await the response from someone who actually knows something. Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted January 16, 2019 Author Report Share Posted January 16, 2019 It would really be a nice feature to have recorded annunciations. If it takes 6 hours to fill a tank, a loudspeaker saying Tank Is Full, or Warning Too Hot or the like. An alarm beeper does not tell anything about the condition. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 16, 2019 MVP 2021 Report Share Posted January 16, 2019 I think that's why they added that feature to the UniStream product line. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 16, 2019 MVP 2021 Report Share Posted January 16, 2019 There are always a few ways to kill that damn cat. Much of my work is what you could call "mechanical animation". So I have been working with sound files matched to plcs since the year dot. Ages ago I thought it was great when I could have CDs running concurrently with actions, instead of cartridge tape players that I'd used up till then! As tech progressed so did my methods. But I have always kept the KISS combined with the "cheap but very effective" principle in mind. If you don't have a need for the sound file to play immediately, (and it looks like a delay of up to a minute might be ok in your situation) then you can get by quite easily by having a simple SD card player with one sound file on the card containing all your messages laid out sequentially with a small bit of silence b/n them. You simply start the player running, and time your method of "speaker output volume adjustment" to turn on when the "time zone" of the relevant message is current. You can then do a simple repeat by restarting the player and doing it all again. So the longest delay is the total length of the sound file. You obviously put your "most demanded, on time" messages as the first ones in the file. You can also get little modules that react to switched inputs to play certain sound bites. With any of this, you have to be prepared to do a little hardware tinkering/mods/soldering....but it isn't rocket science! There....one of my little trade secrets is out! Boo Hoo. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 17, 2019 MVP 2021 Report Share Posted January 17, 2019 And some more info. For systems that need to run different versions at a certain time, like on the 1/4 hour etc, I prestart the sound system before the required time, so that the player has progressed through to the correct sound sequence at the matching time. Some of my files are >10 minutes, with many different sound files. Using the little modules, individual file addressing works fine in theory via more complex interfacing, but I have had issues with the sound system easily confused as to where it is. Remember that these things need to work gliche free without any human help 24/7. The single sound file system above has worked best, because it always starts from a known point. And it is really easy to put together and maintain, needing no fancy hardware apart from 2 or 3 outputs, and is essentially dirt cheap. The players are much like this sort of thing...Google Kentiger HY-502. cheers, Aus Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted January 17, 2019 Author Report Share Posted January 17, 2019 @Ausman Thank you so much for the detailed response. I am going to look at a device and you statedes in the first. The ease will make it worth the money. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 17, 2019 MVP 2021 Report Share Posted January 17, 2019 @Ausman's cleverness never ceases to amaze me! Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted January 17, 2019 Author Report Share Posted January 17, 2019 Check this out, here is an interesting device. A bit pricey, but intriguing to play sound on command. http://www.lt-automation.com/VoiceModule.htm Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 17, 2019 MVP 2021 Report Share Posted January 17, 2019 I love that! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 17, 2019 MVP 2021 Report Share Posted January 17, 2019 The LTM38A looks to be a very useful device. Every so often I cruise google seeing if something more suitable has surfaced, but I've missed this one. That's the nature of web surfing...it might be miles down in the pack when you look, and if you don't know it's name you're stuffed. I particularly like that the serial interface returns what it has been asked to play...a good way to check. And it is stereo. And is an amp. I wouldn't be using the relay(ed) versions because I don't need them and sometimes with the systems you have to be careful in volume control/speaker setup to avoid startup/shutdown thumps. Not good for speakers. The relays on the thing look like they can only be triggered to come on concurrently with the designated file playing. But for your instance, Visco, the ability to perhaps switch different speakers around the installation might be a good thing. One sound device does messages for all plcs and locations? And I'm sure the device has been made to alleviate speaker issues doing just this situation....that's what it appears to have been built for. I know that there are two conflicting opinions in this paragraph!!! Pros and Cons both ways! So.... I would seriously consider it for my next project. The serial control wouldn't be that hard to set up, and the "file on demand" principle would be good and make things a lot easier on more complex installs. cheers, Aus Quote Link to comment Share on other sites More sharing options...
viscoelastic Posted January 17, 2019 Author Report Share Posted January 17, 2019 @Ausman and @Flex727 I am ordering one, I write a review in this post after I get it. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 17, 2019 MVP 2021 Report Share Posted January 17, 2019 33 minutes ago, viscoelastic said: I write a review in this post after I get it. Looking forward to it! Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted January 17, 2019 MVP 2021 Report Share Posted January 17, 2019 Maybe solution is ISD multi message chip http://www.electronics-lab.com/project/voice-recordplayback-module-using-isd1932-isd1964/ Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 18, 2019 MVP 2021 Report Share Posted January 18, 2019 kratmel, I used something like this ages ago and it worked fine in the instance because 8 lots of "speaking" weren't very long and only needed to be mono. The time limit and mono on this style can be an issue in my situations. Visco, how are you planning to trigger things? Serial or multiplex the inputs? If you aren't going to do serial, I'd look at putting on an IO-RO8 as the simplest method given the voltages being switched. In some ways this will be a lot simpler than serial. However, consider that my issues with multiplexing inputs in the past all related to the various modules not being able to handle switch "delays and bounce" adequately, resulting in wrong things being interpreted into the controlling chip due to miniscule variations in timing. That's why I really like the serial system, for better accuracy in the send from the plc, and also sending confirmation back. But also, perhaps this unit can tolerate switch systems better....I haven't fully gone through the manual, only a skim, so maybe there is a setting for input times that would solve all my previous issues. cheers, Aus Quote Link to comment Share on other sites More sharing options...
