Starlord_94 Posted March 26, 2020 Report Share Posted March 26, 2020 Hello, I am just getting started on unilogic. I am having trouble communicating my USC-B5-B1 PLC with USL-070-B05 HMI. Can anyone guide me through the communication process ?? Quote Link to comment Share on other sites More sharing options...
Lenon Patrick Posted March 26, 2020 Report Share Posted March 26, 2020 Hi Starlord. have you checked in these examples? https://unitronicsplc.com/Download/SoftwareVersions/UniLogic/UniLogic_Examples.zip Good luck! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 26, 2020 MVP 2021 Report Share Posted March 26, 2020 I don't think the examples are going to help here. Did you ask for assistance from the company you bought the product from? If they can't help, first you have to set up the Ethernet address and enable the VNC server on the USC-B5. Have you done this part? Then you go to UniApps on the USL and point the VNC client at the USC's Ethernet address. If you've done any kind of program already upload it here so we can have a look. Joe T. Quote Link to comment Share on other sites More sharing options...
Starlord_94 Posted March 26, 2020 Author Report Share Posted March 26, 2020 I have set the panel ip as 192.168.1.5 CPU ip as 19.168.1.4 VNC ip for connection 1 as 192.168.1.6 The HMI's IP from UniApps ethernet setting is 192.168.1.6 When I go on the VNC client and select connection 1 it is not able to connect to the VNC server. I have attached the program below. test.ulpr Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 26, 2020 MVP 2021 Report Share Posted March 26, 2020 Thank you for posting your program. The VNC server was not enabled. It's in a real obvious place (sarcasm) - "Password Management" - and is disabled by default. I enabled it with no password. I recommend you change this in the future if there's anything else on the network. Joe T. Starlord test JT.ulpr 1 Quote Link to comment Share on other sites More sharing options...
Starlord_94 Posted March 26, 2020 Author Report Share Posted March 26, 2020 That worked ! Thank you Joe. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted April 23, 2020 Report Share Posted April 23, 2020 @Starlord_94, sorry about that, and @Joe Tauser, you'are right <sarcasm_deserved> I added a note to the UniStream Display topic, and to the other VNC topics: "To enable VNC Server on a UniStream Controller and set Passwords via UniLogic, click Passwords on the Solution Explorer." with a clickable link to show exactly where that is. Thanks for posting! Quote Link to comment Share on other sites More sharing options...
Bruce Booska Posted February 15, 2022 Report Share Posted February 15, 2022 I've got a similar issue and I'm trying to find a tutorial/video of connecting PLC to HMI for the first time but not seeming to find it. My HMI is USL-070-B05 and my PLC is USC-B5-R38. Any help would be awesome, thanks! Quote Link to comment Share on other sites More sharing options...
