MVP 2021 Joe Tauser Posted February 20, 2021 MVP 2021 Report Share Posted February 20, 2021 @Cara Bereck Levy Take a look at this post, especially near the bottom- If you look at the post reference chain within thus post you'll see that the question of reading floating point values from energy meters is a very recurring theme. It's a common occurrence for word order is always backwards from what Unitronics is expecting. Ask the Creators how hard it would be to add a new type of Operation to the Registers tabs for function 3 and function 4 - "Read Holding Registers Swap Words". If you look at the Official Modbus Protocol Specification- https://modbus.org/docs/Modbus_Application_Protocol_V1_1b.pdf Search for the word "float" you will find no references. This means the byte order of an IEEE 754 floating point value is not specified anywhere and repeated questions on the forum point to the fact that it's kind of the Wild West out there as to how various manufacturers decide to implement it. Unitronics would benefit from making this easier for the end user, as many of them are unaware of this issue. This dovetails with the release of the new UniClould product as we've seen energy meters are a common addition to a UniStream system and that data will certainly be desired on a UniCloud dashboard. Just my 2 cents. Joe T. 2 Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 23, 2021 Report Share Posted February 23, 2021 Got it--will check into this, Joe--thanks! Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 23, 2021 Report Share Posted February 23, 2021 Ok--I don't have a timeline, but this has been added to the To-do feature list! Thanks, Joe! Quote Link to comment Share on other sites More sharing options...
