Gili Posted April 8, 2021 Report Share Posted April 8, 2021 HI! I am new here and this is my first project:) I want to do a Bang Bang temperature control. I want the user to be able to insert the hysteresis (T high and T low) from the HMI. I didn't found a function in the HMI section which allow to insert inputs, Does anyone know of such a function? Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 8, 2021 MVP 2021 Report Share Posted April 8, 2021 Just place a Numeric variable on the HMI screen and check the box for Keypad Entry. 1 Quote Link to comment Share on other sites More sharing options...
Gili Posted April 8, 2021 Author Report Share Posted April 8, 2021 thank you! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 8, 2021 MVP 2021 Report Share Posted April 8, 2021 Gili, if you haven't found it yet, there is a wealth of information in the Help files. In your case it can be found under the Contents tab, shown as HMI Displays. Many users completely miss the existence of the Help files, not knowing how useful they are. cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 9, 2021 MVP 2021 Report Share Posted April 9, 2021 1 hour ago, Ausman said: there is a wealth of information in the Help files Yes, and example projects that came with your VisiLogic installation, and webinars on YouTube. They are quite good. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 9, 2021 MVP 2021 Report Share Posted April 9, 2021 I know, I know, I'll have to change my naming conventions. By Help files I mean everything that's under the Help Tab . 😉 cheers, Aus Quote Link to comment Share on other sites More sharing options...
Ihab Posted April 12, 2021 Report Share Posted April 12, 2021 On 4/9/2021 at 8:01 AM, Flex727 said: Yes, and example projects that came with your VisiLogic installation, and webinars on YouTube. They are quite good. Hi flex.. How i can contact you.. I have unistream plc and need some programming work Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 12, 2021 MVP 2021 Report Share Posted April 12, 2021 3 hours ago, Ihab said: How i can contact you Send me a PM on this board. Quote Link to comment Share on other sites More sharing options...
Ihab Posted April 13, 2021 Report Share Posted April 13, 2021 18 hours ago, Flex727 said: Send me a PM on this board. I m not here most of time.. Can u email me to dicuss Ihab@powerpotentials.com Quote Link to comment Share on other sites More sharing options...
