tim.snelling Posted June 2, 2021 Report Share Posted June 2, 2021 Is there any way to add a Symbol in the Text After field for a Numeric Box? Something that isn't available from the Symbol button? For Example the Ohm/Omega Ω symbol? Thanks, Tim Snelling Quote Link to comment Share on other sites More sharing options...
sgull Posted June 2, 2021 Report Share Posted June 2, 2021 Hi Tim You can use any document program like WORD to type the symbol you want. Then copy the symbol and paste it into the TEXT AFTER field. Regards Denis Quote Link to comment Share on other sites More sharing options...
tim.snelling Posted June 3, 2021 Author Report Share Posted June 3, 2021 Thanks Denis, i was able to get that to work. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 3, 2021 MVP 2021 Report Share Posted June 3, 2021 19 hours ago, sgull said: You can use any document program like WORD to type the symbol you want. Then copy the symbol and paste it into the TEXT AFTER field. Well, I learned something today. Thanks @sgull! 1 Quote Link to comment Share on other sites More sharing options...
